Legacy Software
Insight
Runout Check and Sphere Measurement Procedures Using FARO Insight
Runnout Check: Measure a RetroProbe reset point at with the RetroProbe in 8 different positions / orientations while 3000 samples.
Sphere Measurement: Scan certified a sphere such as a tooling ball. Used floated radius for fit. Scan 250 points at 0.1 inch interval. Check the radial fit error as well as the overall diameter fit.
Keywords: Insight, Insight Software, Checking SMR, Checking RetroProbe, Inspect SMR, Inspect RetroProbe, Testing SMR, Testing RetroProbe, SMR Runnout Check, RetroProbe Runnout Check, Tilt Test, Tracker Accessories, Laser Accessories, Backsight Test
  • Was this article helpful?
