Export Issues with Polyline Data to CAD Formats in Measure 10 or Q
When attempting to export polyline data to CAD (like IGES or STP), ensure that "Show construction lines" is enabled in Preferences during the export of the CAD file. If you are bringing the file back into Measure, also ensure that "Show construction lines" is enabled before import as well.
In Measure Q:
To enable "Show construction lines" go to Edit > Preferences > Display > CAD View tab > CAD Settings. You will see a checkbox toggle for "Show construction lines". Enable it to export polyline data to CAD.
In Measure 10:
To enable "Show construction lines" go to File > Preferences > Display > CAD View tab > CAD Settings. You will see a checkbox toggle for "Show construction lines". Enable it to export polyline data to CAD.
polyline, export, Measure Q, Measure 10
  • Was this article helpful?
