Remove the CAD Image from a Report in Measure 10
Go to the report section, at the top click on the home tab select “edit layout”. On the body of the program there will be a line called “CADheaderimage”, this line has to be deleted in order to remove the image.
After removing this line save the template in the following path:
C:\Program Files\FARO\CAM2 Measure 10\DevExReport.
Close the software and reopen the file you were working on, go to report and load the template that was saved by selecting it from the drop down on the home tab in the report section.
report, image, header, 10
  • Was this article helpful?
