Resetting Communications between CAM2 and the Laser Line Probe
You can do one of the following two procedures to reset the communications between the CAM2® software and the Laser Line Probe (LLP).
  1. Reboot your computer while leaving the FAROArm® on. This will close all the communications to the arm and software. Restart CAM2.
  2. Close the software, turn off the DAC server by right clicking on it and exiting (the computer looking icon in your open task menu typically in the bottom right of your task bar), and turn off the FARO USB driver by right clicking on it and unloading (the USB icon in the open task menu). Leave the arm on the entire time. Now restart CAM2.
CAM2, LLP, scanning, reverse engineering, missing option, grey, not available
