Quantum X.S
Quantum X.M
Quantum X.E
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
Legacy Gage
Bluetooth
Plus
Standard
Power
Serial FaroArm
Bronze
Gold
Silver
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Granite Work Cart FAQs
ACCS0164 Work Cart
FARO offers a selection of tripods, rolling stands, and mounting options. See the following articles for more information:
There have been two models of the granite work cart offered:
Part# Approximate Granite Top Dimensions Units
ACCS0164 36" x 24" x 4.25" (914mm x 610mm x 108mm Imperial
20156* 48" x 24" x 5.7" (1219mm x  610mm x 144mm) Metric
* EMEA region only, contact your FARO sales representative for availability.
Each are a convenient work center for the FaroArm® operator. In addition to the precision granite work surface the carts also provide convenient storage spaces for your computer, monitor, tools, probes, and extension cords (all sold separately).
General Specifications
  ACCS0164 20156
Country of Origin Made in Taiwan Made in Taiwan
Granite Grade Grade A (not certified) Grade A (not certified)
Granite Weight Capacity 400 lbs (181kg) 400 lbs (181kg)
Cart Weight 800 lbs (363kg) 966 lbs (438 kg)
Threaded Inserts
Across the granite top there are threaded inserts that accept workholding hardware (threaded rods, hold downs, etc) to hold/fixture your part. Also provided are two mounting locations for the FaroArm 3.5" mounting ring.
WARNING: To avoid cracking the granite top, DO NOT tighten fasteners in the threaded inserts beyond 50 in/lbs (6 N/m).
ACCS0164
  • Mounting Ring Inserts: 10-32 (3 per mounting location)
  • Workholding Inserts: 3/8-16 UNC-2B (14x)
  • ACCS0164 Drawing (PDF)
20156
  • Mounting Ring Inserts:  M5 x 0.8 (3 per mounting location)
  • Work-holding Inserts (top): M10 x 1.5 (64x)
  • Work-holding Inserts (side): M20 (1x)
  • 20156 Drawing (PDF)
