Granite Work Cart FAQs
There have been two models of the granite work cart offered:
Part# | Approximate Granite Top Dimensions | Units |
ACCS0164 | 36" x 24" x 4.25" (914mm x 610mm x 108mm | Imperial |
20156 (no longer available) |
48" x 24" x 5.7" (1219mm x 610mm x 144mm) | Metric |
Each are a convenient work center for the FaroArm® operator. In addition to the precision granite work surface the carts also provide convenient storage spaces for your computer, monitor, tools, probes, and extension cords (all sold separately).
General Specifications
ACCS0164 | 20156 | |
Country of Origin | Made in Taiwan | Made in Taiwan |
Granite Grade | Grade A (not certified) | Grade A (not certified) |
Granite Weight Capacity | 400 lbs (181kg) | 400 lbs (181kg) |
Cart Weight | 800 lbs (363kg) | 966 lbs (438 kg) |
Threaded Inserts
Across the granite top there are threaded inserts that accept workholding hardware (threaded rods, hold downs, etc) to hold/fixture your part. Also provided are two mounting locations for the FaroArm 3.5" mounting ring.
WARNING: To avoid cracking the granite top, DO NOT tighten fasteners in the threaded inserts beyond 50 in/lbs (6 N/m).
ACCS0164
- Mounting Ring Inserts: 10-32 (3 per mounting location)
- Workholding Inserts: 3/8-16 UNC-2B (14x)
- ACCS0164 Drawing (PDF)
20156
- Mounting Ring Inserts: M5 x 0.8 (3 per mounting location)
- Work-holding Inserts (top): M10 x 1.5 (64x)
- Work-holding Inserts (side): M20 (1x)
- 20156 Drawing (PDF)
