Laser Tracker
ION
Si
X
Xi
Angular Accuracy or Backsight Errors with the Laser Tracker
The best way to check angular accuracy or backsight errors is to run the Angular Accuracy Checks from the CompIT menu. The best way to improve the angular accuracy or backsight error is to run Quick Compensation / Self Compensation or the Pointing Compensation in CompIT.
Keywords: backsights, angular accuracy, backsight checks
