2026
2025
Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
Error- Hardware Error using Measure Level Function in CAM2
With the Vantage S/ E / S6 / E6 Laser Trackers using CAM2 2019, there are have been reports of the Measure Level plane function failing and/or resulting in CAM2 to stop responding.
Symptoms
  • Error message displayed: "The Laser Tracker has detected an unknown hardware error. Make sure the Laser Tracker is turned on and properly connected."
  • CAM2 stops responding while using Measure Level plane function.
  • CAM2 crashes during Measure Level plane.
  • No plane feature found after Measure Level plane completion.
Solution
 Firmware update (2.6.4.5) for the Laser Tracker Vantage S/E has been reported to resolve this . Download it here.
