Laser Tracker
ION
Si
X
Xi
Internal Level Usage for Side Mounted Laser Trackers
The Tracker's level can only be used when the Tracker is in the vertical upright position and the Bubble Level from the Tracker pad shows a green dot. It can not be used if the Tracker is on its side or upside down.
See Also
sideways, mounting, laser tracker, sideways mounting
