Laser Tracker
ION
Si
X
Xi
Location of the StartupChecksLog.txt File for Startup Checks
This article details the location of the StartupCheckslog.txt file. This file contains information pertaining to the Startup Checks that can be useful for diagnostics.
Details
The StartupCheckslog.txt file is placed in the folder listed below. This file contains information pertaining to the Startup Checks that can be useful for diagnostics.
  • For Vantage tracker or later:     C:\ProgramData\FARO Laser
  • For ION tracker or earlier:         C:\FARO_CompIT_Data
If Startup Checks was never run on the particular computer being used at the time, the StartupChecksLog.txt file will not be on the computer. Once Startup Checks has been run once, the specific folder and subsequent Startup Checks will log information to the StartupChecksLog.txt file. It will not record information from previous Startup Check attempts though.
Startup Checks, Log File
