Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
Software Download of FARO Utilities for the Laser Tracker
 Laser Tracker Vantage Icon
Download and Install
  1. Click here to download the latest FARO® Laser Tracker Utilities, version 5.0.0.7, released Apr 2026.
Supported Hardware
  • VantageS6 and VantageE6
  • VantageS and VantageE
  • Vantage
  • ION
  • Xi
  • X
  • Si
Windows 7 or 10 - FARO Laser Tracker Utilities 2.2.1 or Earlier Issue
A known issue with FARO Utilities while using Windows 7 or 10 is the inability to use Find Trackers on versions 2.2.1 and earlier. This is a common way for to change the IP address of the tracker or to determine the current IP address if another operator has changed it.
FARO Utilities version 2.2.2 released in Feb 2011 resolves this issue.
If using FARO Laser Tracker Utilities 2.2.1 or earlier, to change the IP Address of the tracker using Windows:
  • Open Laser Tracker Utilities
  • Click Connect to connect to the tracker at 128.128.128.100.
  • Open Tracker Pad from the Utilities
  • Press the "Set IP Address..." button down towards the bottom.
  • A reboot of the Tracker will be required for the new IP address to work.
If you change the IP address of the tracker, you may want to place a label on the tracker indicating its new IP address.
See Also
faro utilities, faroutilities, tools, utilities, cleanup
