Wireless Connectivity Issues With the Vantage Laser Tracker
The configuration of your computing environment or the configuration settings for the FARO® Laser Tracker Vantage may cause wireless connectivity issues, making the Vantage not appear on the list of available devices that can connect to your network.
Solution
To fix this issue, reset the Vantage by following the instructions in the User Manuals for the Laser Tracker, the Connection Problems section. This resolves most wireless connection problems.
If the problem persists, follow the instructions in the Powering Down and Powering Up sections of the manual to reset the connectivity settings.
