Serial FaroArm
Bronze
Gold
Silver
Connecting a Serial FaroArm to a USB port using a USB to serial port adapter
Faro does not recommend or guarantee the outcome from this configuration. We do not support these adapters.
It is possible to connect a FARO arm to a USB port using a USB to serial port adapter. However there are some restrictions that we have found:
  1. This configuration must be used with Windows 2000 or newer. Windows NT will not support it.
  2. The adapter must be installed on COM1.
  3. This adapter may have problems when connecting through a USB hub.
  4. Some of these adapters do not change baud rates based on software commands, so if a user must change the arm baud rates, then they will also need to change the baud rate of the port manually in the Windows control panel.
  5. The user will need a null modem cable or null modem adapter to connect to the power module. The only one we've found that works reliably is the Quatech SSU-100.
usb serial, serial to usb, usb converter, usb adapter, usb adaptor, adapter
