3D Hand Held Scanner
Freestyle3D Objects
Freestyle3D X
Freestyle3D
Maximum Performance While Scanning with the Freestyle3D
  • Set the power management of your system to maximum performance. (both on battery/power supply mode)
  • Don’t run any other applications while scanning
  • Check the settings of security software (if necessary, exclude SCENE Capture/Freestyle3D Drivers under -> Guard -> Scan -> Exception)
  • For a better performance and post-processing (especially for big sized projects) we prefer using the SSD (Solid-State-Drive)
See Also
power usage, power saver
