Fusion
Prime
TrackArm Accessory Kit and Supported Software
The FARO TrackArm Accessories Kit enables you to unite a FaroArm Edge, Prime, or Fusion with a Vantage Laser Tracker to inspect small and large part components. Switching between the FaroArm and Tracker you can reach hidden points, even around corners and inside holes.
The Laser Tracker Accessories Manual contains information about how to work with the TrackArm Accessories Kit. The kit contains these items.
TrackArm Accessries Kit
Here is a list of the part inspection software that is seamlessly integrated with the TrackArm.
Third-party part inspection software vendors interested in integrating with the TrackArm may contact FARO Products Management for details.
