As-Built
Modeler
As-Built Modeler Training - Part 14 - Cylinder Creation
As-Built Modeler provides tools to extract cylinders from point cloud data. Cylinder extraction can be performed “Supervised” and “Unsupervised”.
  • Using the “Supervised” (Create Cylinders) command requires the user to click points within the point cloud to define the cylinder. The use of Scan Data Noise, Search Radius, and Automatic Cylinder Extension settings allow the user to fine tune the results.
  • Using the “Unsupervised” (Detect Cylinders) command, the software will attempt to recognize cylinder data within the point cloud and automatically create cylinder features. The use of clipping boxes and additional detection parameters restrict the search to produce the most accurate results.
Video
Cannot view the video? Click here to download this video.
