As-Built
Revit
Getting Started with As-Built for Autodesk Revit
The FARO® As-Built™ for Autodesk® Revit® is the follow-up product of PointSense for Revit and contains all its functionality and more. As-Built for Revit is available in many languages.
As-Built for Revit is a perfect complement for users working with point cloud data in Autodesk Revit. This add-on offers processing functionality of scan data with customized commands for modeling and detailing BIM elements.
What's New?
Learn what's new in the current version... Download
Getting Started Tutorials
Tutorial 1: Modeling a Room in Revit
After this tutorial you will be able to:
  • Prepare a point cloud for fittings the walls
  • Create the walls relative to the point cloud
  • Create doors and windows
Download Tutorial Material
Tutorial 2: Modeling a Room with SendTo As-Built Modeler
  • Create a Wall
  • Create Doors and Windows
  • Work with construction aids
  • Create Beams and Columns
Tutorial 3: Creating Pipe Runs
  • Fit pipes
  • Place Pipe fittings
  • Align pipe runs
  • Insert pipe accessories
Tutorial 4: Structural Framing from Point Clouds
  • Fit structural beams and columns
  • Align structural elements
  • Create a closed structural frame
Feature Videos
Looking for more videos... Click Here
 Place Pipe Fittings and Align Pipes
Fit Pipe
Fit Polygon
Section Manager
 Surface Analysis
 Clash Detection
 Align Walls
 Prepare Point Cloud and Fit Wall
 USIBD Surface Analysis
Tips & Tricks
Videos
 Export an RCP Point Cloud from SCENE
 Create an RCP Point Cloud with ReCap
 Inserting a RCP Point Cloud and Set the Project North
 Creating a Topographical Surface
 Align Scans to a BIM Model Using SCENE and Revit
  • Was this article helpful?
