Computer System Requirements for CAM2
System Requirements
Before you install the latest or earlier version of FARO® CAM2®, check that your system meets the minimum system requirements.
Hardware Probe Essentials* Probe Professional** Scan Professional / Expert***
Processor† 12th Gen Low Performance i5 or above 12th Gen High Performance i7 or above 12th Gen Extreme Performance i9 or above
RAM 16 GB 32 GB 64 GB
Hard Drive 500 GB SSD 512 GB NVME 1 TB NVME
Graphics
NVIDIA Quadro T500
NVIDIA RTX 2000
NVIDIA RTX 5000
USB Port†† 1 (2 if using portlock license) 1 (2 if using portlock licnese) 1 (2 if using portlock license)
Virtual Machine (VM) Install Supported
Remote Desktop Accessibility CAM2 2018: Not Supported; CAM2 2019 and later: Supported
* For Point Probe Measurements | **For Point Probe Measurements with Large CAD, Moderate Point Cloud Scanning | ***For Leap ST / Intensive Point Cloud Scanning
† The FaroArm USB driver requires an Intel or AMD processor with x64 architecture.
†† The FARO device should always be connected directly to the computer and not via a USB hub.
Note: A 4K display monitor is not currently recommended.
Supported NVIDIA Graphics Cards and Drivers
Family Model NVIDIA Driver
Quadro RTX 4000, 5000, 6000, 8000 551.52 or greater
Quadro P6000, P5000, P4000, P2000, P2200, P5000
M520, M6000, M5000, M4000, M2000, M2200
K5200, K4200, K2200, K620, K420
K5000, K4000, K2000, K6000
Supported Operating Systems
Please refer to the following article for specific version support: Microsoft Windows Operating Systems That Are Compatible With FARO Software
See Also
CAM2, release notes, readme, new features, specifications, software requirements, install, installation, specs, specifications, hardware, CAM2 specs, computer requirements, minimum requirements
