2026
2025
Creating Composite Datums in CAM2
Composite Datums are required when 2 datum features are both seen at the primary datum. Composite datums combines 2 datum features of the same type, to allow both to be uses as the primary datum in GDT callouts.
Download a PDF of this procedure:  GDT003: Creating Composite Datums
Preparation
  1. Create the datum features as detailed in Applying Datums to Features in CAM2.
Creating a Composite Datum
  • From the GDT ribbon select Composite Datums
  • In the Manage Composite Datums window:
    • Highlight the datum letters needed in the LH pane
    • Select Create to create the composite datum in the RH pane
    • Select Close
  • The composite datum will now be available for use within GDT call-outs.
See Also
GD&T, Help Sheet, GDT003
