2026
2025
Importing Shortcuts into CAM2
Shortcuts allow you to define quick composite measurement commands or macros, such as the length between two circles, a custom coordinate system, or a bolt-hole pattern. These can be executed from a single icon within the Automation ribbon. Shortcuts can be created by and shared amongst users.
Download a PDF of this procedure:  IM001: Importing Shortcuts into CAM2
Preparation
  • Save the Shortcut files (.xml) to a location on the pc
Method
From within CAM2’S Automation ribbon:
  • Select Import
  • Browse to the saved location
  • Select the Shortcut
  • Click Open
The Shortcut will be imported and displayed in the Shortcut Gallery, and can be executed by double clicking the icon.
See Also
Help Sheet, IM001
