2026
2025
Set-Up and Operation of CAM2 Remote
When you are using a FARO® 3D measurement device in the field, the distance between the inspection part, the FARO device, and the computer running CAM2® can complicate taking the measurements you need. The greater the distance, the more awkward this can be. Remove all obstacles by using FARO CAM2 Remote and an iOS device to remotely control CAM2 and the FARO device.
Download the document below for information on how to download, configure, and run CAM2 Remote.
CAM2 Remote Set-Up
  RMT001: CAM2 Remote Set-Up
See Also
Help Sheet, RMT001
