2026
2025
Setting Measurement Units and Displayed Decimal Places in CAM2
Enabling the quick access Unit Format icon to be displayed in the CAM2 toolbar will allow you to quickly switch between units. It also provides access to the customize units window, where the number of displayed decimal places for each unit can be set.
  1. On the top CAM2 toolbar select the Quick Access Toolbar icon and click Unit Format.
  2. This will display the Unit Format icon and provide the ability to quickly switch between units. To to change the decimal places of a given unit, click the Unit Format icon and then click Customize Units.
  3. The Customize Units window will appear allowing you to change the decimal places and other unit parameters.
  • If you would like to change the decimal place for the Digital Read Out (DRO). Open Preferences under the Home tab and navigate to Panels > Measurement window > Decimal places.
