Shortcut Downloads for CAM2
Shortcuts allow you to define quick composite measurement commands or macros, such as the length between two circles, a custom coordinate system, or a bolt-hole pattern. These can be executed from a single icon within the Automation ribbon. Shortcuts can be created by and shared amongst users.
FARO® has provided a library of Shortcuts for CAM2® covering a wide range of common workflows. These Shortcuts are free to download and can also be modified for your application. For information on importing a Shortcut, see Importing Shortcuts into CAM2.
CAM2 Shortcut Descriptions
Available Shortcuts are described below. Simply click on the File Name to download, or to browse/download the entire Shortcut library click here.
Icon File Name Description
Angle 2 Cylinders.xml
Prompts the user to measure two cylinders, then calculates the angle between the center lines (axis). Note: the Angles a sensitive to the direction probed.
Angle 2 Lines.xml
Prompts the user to measure a plane and two lines, then calculates the angle between the two. Note: the angle is sensitive to the probed direction of the lines.
Angle 2 Planes.xml
Prompts the user to measure two planes, then calculates the angle between the vectors of the two planes.
Angle 3 Circles.xml
Prompts the user to measure a plane and 3 circles, and calculates the angle between the three circles, where the third measured circle is the apex of the angle.
Angle Cone Plane.xml
Prompts the user to measure a cone and plane, then calculates the angle between the cone center line (axis) and plane surface.
Angle Cylinder Plane.xml
Prompts the user to measure a cylinder and plane, then calculates the angle between the cone center line (axis) and plane surface. Note: the angle is sensitive to the probed direction of the cylinder.
Circle Cone-Cylinder.xml
Prompts the user to measure a cone and cylinder, then constructs a circle at the intersection of the two features. Note: features must actually intersect otherwise the circle will not be constructed.
Circle Cylinder-Sphere.xml
Prompts the user to measure a cylinder and a sphere, then constructs a circle at the intersection of the two features. Note: features must actually intersect otherwise the circle will not be constructed.
Circle Plane-Cone.xml
Prompts the user to measure a plane and cone, then constructs a circle at the intersection of the two features. Note: features must actually intersect otherwise the circle will not be constructed.
Dove-tail Seal Groove.png Dove-tail Seal Groove.xml Prompts the user to measure two planes, and two coaxial cones (tapers) to calculate the upper groove width and groove depth at four positions. This feature is commonly used in the Oil & Gas industry.
Length 2 Circles.xml
Prompts the user to measure a plane and two circles, then calculates the distance between the center points of the two circles.
Length 2 Cylinders.xml
Prompts the user to measure two cylinders, then calculates the distance between the center lines (axis) of the two. Note: cylinders must be parallel with 3° otherwise the length will not be calculated. The length is calculated from the mid point of the first cylinder axis projected perpendicularly onto the axis of the second cylinder. Then the distance between the two points is calculated.
Length 2 Lines.xml
Prompts the user to measure a plane and two lines, then calculates the distance between the lines. Note: lines must be parallel with 3° otherwise the length will not be calculated. The length is calculated from the mid point of the first line projected perpendicularly onto the second line. Then the distance between the two points is calculated.
Length 2 Planes.xml
Prompts the user to measure two planes, then calculates the distance between the planes. Note: planes must be parallel with 3° otherwise the length will not be calculated. The length is calculated from the center point of the first plane projected perpendicularly onto the second plane. Then the distance between the two points is calculated.
Length Circle Line.xml
Prompts the user to measure a plane, line and circle, then calculates the shortest distance between the circle center point and the line.
Length Point Line.xml
Prompts the user to measure a plane, line and point, then calculates the shortest distance between the point and the line.
Max Length 2 Circles.xml
Prompts the user to measure a plane and two circles, then calculates the distance between the circle outer edges.
Max Length Circle Line.xml
Prompts the user to measure a plane, line and circle, then calculates the maximum distance between the line and the furthest edge of the circle.
Min Length 2 Circles.xml
Prompts the user to measure a plane and two circles, then calculates the distance between the circle inner edges.
Min Length Circle Line.xml
Prompts the user to measure a plane, line and circle, then calculates the minimum distance between the line and the closest edge of the circle.
PCD 3 & Angles.xml
Prompts the user to measure a plane and three circles, then constructs a best fit circle through the circle center points. The angles between the circles are also calculated, using the constructed circle center point as the apex.
PCD 3.xml
Prompts the user to measure a plane and three circles, then constructs a best fit circle through the circle centers.
PCD 4 & Angles.xml
Prompts the user to measure a plane and four circles, then constructs a best fit circle through the circle center points. The angles between the circles are also calculated, using the constructed circle center point as the apex.
PCD 4.xml
Prompts the user to measure a plane and four circles, then constructs a best fit circle through the circle centers.
PCD 5 & Angles.xml
Prompts the user to measure a plane and five circles, then constructs a best fit circle through the circle center points. The angles between the circles are also calculated, using the constructed circle center point as the apex.
PCD 5.xml
Prompts the user to measure a plane and five circles, then constructs a best fit circle through the circle centers.
