2026
2025
Supported CAD Import/Export File Formats for CAM2
As of CAM2® 2018.10, “premium” CAD formats are no longer sold separately, and now supports direct import of all major CAD formats at no additional cost. This delivers confidence knowing that any file from any proprietary source can be read directly into CAM2.
The ability to directly load the native CAD file also improves the fidelity of the resulting CAD data that is used in CAM2 as it eliminates a common double translation to and from open CAD formats, which can be the cause of many surface issues.
CAM2 supports the import/export of the following CAD formats:
Vendor File Type Extensions Supported Versions Import Export Premium Translator
(pre Ver. 2018.10)
Open Formats IGES *.igs; *.iges Versions 5.1, 5.2, 5.3 X X
PRC *.prc All versions X
STEP *.stp; *.step; *.stpz AP 203 E1/E2, AP 214, AP 242 Ed1, Ed2 & Ed3 X X
STL *.stl All versions X X
VDA-FS *.vda Versions 1, 2 X X
Dassault Systèmes ACIS *.sab; *.sat Up to 2025 X   X
CATIA V4 *.model; *.session; *.dlv; *.exp Up to 4.2.5 X   X
CATIA V5 *.CATProduct; *.CATPart; *.CATDrawing; *.CATShape; *.cgr; *.3dxml Up to V5_6R2025 X   X
CATIA V6 *.3dxml Up to V5_6R2024 X   X
Solidworks *.sldasm; *.sldprt From 97 up to 2025 X   X
Autodesk Inventor *.ipt; *.iam Up to 2026 X   X
AutoCAD 3D *.dwg; *.dxf Up to AutoCAD 2026 X
PTC PTC Creo *.asm; *.neu; *.prt; *.xas; *.xpr Pro/Engineer 19.0 to Creo 12.4 X   X
Siemens I-deas *.mf1; *.arc; *.unv Up to 13.x (NX 5), NX I-deas 6 X
JT *.jt Up to v10.9 X   X
NX *.prt UG11 to UG18, UG NX, NX5 to NX12, NX1847 to NX2506 X   X
Parasolid *.x_b; *.x_t; *.xmt; *.xmt_txt Up to v38 X X
Solid Edge *.asm; *.par; *.pwd; *.psm 1 to 20, ST1 to ST10, 2019 to 2025 X
Rhinoceros Rhino3D *.3dm Versions 4 to 8 X
Latest updates are in red.
See Also
CAD file conversion, converter, CAD compatibility, CAM2
