2022
Exporting Panoramic Images
SCENE 2018 allows users to export full-color panoramic images, directly from a scan project. Scans made with FARO® scanner models M70, S70, S150, S350 and later create 165 megapixel images. Scans from older scanners only output panoramic images with 40 megapixel images.
Details
  1. In the Structure view, right-click a scan, then click Import/Export > Panoramic Image and choose either Scan Resolution or Full Color Resolution.
  2. Select Scan Resolution to create images that have the same color resolution as the scan, or select Full Color Resolution, if you want to create a .PNG panoramic image with the highest color quality possible.
    Note: Panoramic images are compensated to remove the offset between the two halves of the scan, as well as any distortion cause by the scanner’s rotation. Full-color resolution panoramas have a white stripe at the bottom of the picture because the proportions of the scan and the picture are different.
  3. If you are exporting a Scan Resolution panoramic image, you will be able to choose the image file type and rename the image being exported.
  4. If you are exporting a Full Color Resolution panoramic image, you will only be able to select the export folder. Exporting the scan a second time will overwrite the first image if it has not been renamed.
    Note: To export multiple scans, click the scan group in the Structure view and follow the above instructions.
See Also
Keywords
scene 2018, hd, panorama image
