2022
Process Freestyle Handheld Scans in SCENE
FARO® SCENE version 2019.1 or later allows users to import, process, and register scans made with a handheld scanning device.
Details
Use the steps below to process hand-held scans.
  1. Click Process Handheld Scans on the Processing ribbon.
  2. Select the scans or scan cluster.
  3. Click Configure Processing.
  4. Configure scan processing options.
    • Marker Detection
      • On/Off - Toggles marker detection for all processing.
      • Auto - Uses marker detection only if it was switched on when the scan was created.
      • Tracking - Only markers are used for tracking.
    • Plane Detection
      • On/Off - Toggles plane detection for all processing.
      • Auto - Uses plane detection only if it was switched on when the scan was created.
    • Replay - If scans have already passed some processing steps, Replay restarts the processing from the beginning. Processing is then executed with higher precision than it was done during capturing.
    • Scan Optimization - Adjusts all frames of a scan to minimize the overall displacements errors and close loops. The Extended setting may give better results but will take longer.
    • Stray Point Filtering - Removes stray scan points.
      • Standard - Removes stray points without additional 3D smoothing. This setting tends to make edges and corners look better.
      • Smooth - Removes stray points with additional 3D smoothing. This setting tends to make planes look better.
    • Color Optimization - Averages the color of scan points in overlapping areas within a scan, and adjusts color effects caused by different lighting situations.
    • Delete Raw Data - Deletes the raw scan data and the project history after processing is complete. Note: Select this option only if you are sure that you never want to process the scan again.
  5. Click Start Processing.
  6. Click Ok when processing is complete.
