FARO Zone 2D FARO Zone 2D - 2018 FARO Zone 2D - 2019 FARO Zone 2D - 2020 FARO Zone 2D - 2021 FARO Zone 2D - 2022 FARO Zone 2D - 2023 FARO Zone 2D - 2024
Hand Held Scanner 2D Hand Held Scanner - ScanPlan 3D Hand Held Scanner - Freestyle3D 3D Hand Held Scanner - Freestyle3D X 3D Hand Held Scanner - Freestyle3D Objects 3D Hand Held Scanner - Freestyle 2 3D Hand Held Scanner - Leap ST
Laser Scanner 3D Laser Scanner - Focus Core 3D Laser Scanner - Focus Premium Max
SCENE SCENE - 2019 SCENE - 2go App SCENE - 2020 SCENE - 2021 SCENE - 2022 SCENE - 2023
2022
7.x
Processing and Registering Scans with SCENE
Processing and registering scans in SCENE is an intuitive process that begins after you have imported your scan data.
Process Scans
  1. Open the project.
  2. Click Project on the SCENE ribbon.
  3. Click Process Scans under Processing.
  4. Select the scans to process and click Configure Processing.
  5. Adjust the processing settings as desired.
  6. Click Start Processing.
If you get a screen that says processing failed it is likely that the SCENE couldn’t register the scans on its own. This could be for a couple of different reasons:
  • There may not be enough overlap between the scans.
  • The surfaces in the scene may be difficult to register, like blowing trees and tall grass.
  • Rooms or surfaces in one area of the scene may look similar to other areas in the scene which can throw off registration. Mirrors in the scene could duplicate a room.
Register Scans
Even if the scans registered successfully during the project transfer, you will need to view and verify the registration.
  1. On the project page, click Registration to check.\
  2. Click Verify Registration or the Scan Report icon.
  3. On the Register and Verify page, use the view toolbar at the bottom to compare your scans from different angles.
  4. If the scans are registered correctly, click Yes and Finish.
  5. If not, click No and Finish. You will be directed to register the scans again.
You can register scans later, by clicking the Registration tab on the SCENE ribbon.
Legacy Tutorials
SCENE 6 with SCENE 2go.
  Download the tutorial PDF.
SCENE 6 with Webshare 2go 2.0
  Download the legacy tutorial PDF
