FARO Sphere
Sphere
3D Laser Scanner
Focus Core
Focus Premium
Focus Premium Max
FARO Flatness Check App
FARO® Flatness Check is an iPad app that works with your FARO Focus laser scanner to quickly find and document flatness variations in concrete slabs and other floor surfaces. With FARO Flatness Check's easy workflow, a construction specialist with a Focus and an iPad can check the flatness of a slab—a reality capture expert is not needed.
FARO Flatness Check also enables you to visualize your analysis result in augmented reality. You can view the floor through FARO Flatness Check, and see a heat map of flatness variations superimposed onto it. This makes it easy to find places on the floor that need attention.
If you upload your Flatness Check project to the cloud via FARO Sphere XG, you can use BuildIT to validate slab quality against common standards (i.e., ASTM 1155, DIN18202, TR34) and can document that quality for your stakeholders. (Note that Sphere XG and BuildIT have additional licensing requirements.)
Download and Device Support
Install the FARO Flatness Check app via the App Store on your iPad. If you are a already a FARO Sphere XG user, you can also install the app by scanning the QR code on the installation tile.
iPad Support
Currently the Flatness Check app is only supported for use on the Apple iPad, iOS 14 or greater. The table below table lists recommended device/model information.
Recommended - Superior Experience Recommended - Great Experience* Not Recommended - Can Download* Not Supported - Download not available*
  • iPad Pro 11" 2nd - 3rd generation
  • iPad Pro 12.9" 4th to 5th generation
  • iPad Pro 11" 1st generation
  • iPad Pro 12.9" 3rd generation
  • iPad Mini 5th - 6th generation
  • iPad Air 5th generation
  • iPad Pro 9.7" / iPad Pro 10.5"
  • iPad Pro 12.9" 1st & 2nd generation
  • iPad Mini 4th generation
  • iPad Air 3rd - 4th generation
  • iPad 7th - 9th generation
  • iPad Mini 1st -3rd generation
  • iPad Air 1st - 2nd generation
  • iPad 1st - 6th generation
Models:
A2229, A2069, A2232, A2233, A2228, A2068, A2230, A2231, A2377, A2459, A2301, A2460, A2378, A2461, A2379, A2462
Models:
A1876, A1895, A1983, A2014, A1980, A1934, A1979, A2013, A1233, A2124-A2126, A2568, A2588, A2589, A2591
Models:
A1584, A1652, A1673 - A1675, A1670, A1671, A1701, A1709, A1538, A1550, A2123, A2152-A2154, A2316, A2072, A2324, A2325, A2197 - A2200, A2270, A2428 - A2430, A2602 - A2605
Models:
A1432, A1454, A1455, A1489 - A1491, A1599 - A1601, A1474 - A1476, A1566, A1567, A1822, A1823, A1893, A1954
* The "hide cloud behind objects" feature does not function with these models.
Need help Identifying your iPad model? See the Apple Support Article for instructions.
Laser Scanner Support
The Flatness Check app supports the following FARO Laser Scanner models: Focus Premium, Core, FocusS Plus, FocusS, and FocusM (with firmware 6.80 or greater).
User Manual
Click the link below to download the FARO Flatness Check User Documentation.
 Flatness Check User Documentation - English (online)
Flatness Check User Documentation - English (PDF)
Installation and Setup
  1. Install the FARO Flatness Check app using the App Store on your iPad. If you are a FARO Sphere XG user, you can also install the app by scanning the QR code on the installation tile.
  2. Flatness Check also requires a FARO Sphere XG account.
  3. Open the Flatness Check App on your iPad
  4. You will be prompted to sign-in to your Sphere XG Account (or create one).
  5. Once signed in, licensed users can begin using the app. If you are using the app for the first time, you can use the built-in 30 day trial license. To obtain a full license, contact your FARO representative.
License Management in Sphere XG
Owning a FARO Sphere XG account, enables customers to manually share the Flatness Check license between the different users. To do so, the account admin can move the Flatness Check Permission from one user to another in the Sphere XG User Management.
FAQs
Can I install the App on my iPhone?
As of today, no. The iPhone will be not be supported and installation is not possible as we want to provide you an excellent experience with the App.
I want to continue after the trial period. How do I do that?
We’re glad you like the App. To continue using the App you must purchase a license from FARO. We offer a 1-year subscription at a very attractive price. If you haven’t been contacted by a FARO Sales representative, please get in touch with us here.
What is needed to have the App run my laser scanner?
The Flatness Check app supports the following FARO Laser Scanner models: Focus Premium, FocusS Plus, FocusS, and FocusM with firmware 6.80 or greater. The App can’t support older FARO Laser scanners or Laser Scanning Solutions from other vendors.
I can’t upload project data from the Flatness Check App into Sphere XG. What do I need to do to enable this?
Most likely the issue is that a "workspace" was not created within FARO Sphere XG after the registration process. Such a workspace is required, so that FARO Sphere XG has a location for allocating your project data.
To create the workspace in Sphere XG, simply go to Options (click on the top right corner icon) and then Account Settings. You now should be able to create the workspace.
After completion you can identify the workspace in the App and upload your project data. Now you can invite other stakeholders to the Sphere XG workspace and share the results online. For more information on Sphere XG Workspaces, you may also want to check the Sphere XG User Manual.
How can I document Floor Flatness and Levelness against regional standards with the App?
At launch the App will not offer this capability. The Apps core value is in the extreme fast visualization of tolerance deviations on the floor through Augmented Reality. If its required to document slab quality against regional standards, you can transfer the captured data via FARO Sphere XG into FARO BuildIT Construction and perform the standard analysis there. The results from the analysis in BuildIT Construction can then be uploaded into Sphere XG and then via download, visualized through the Flatness Check App.
How can I get training on the App?
For this App it is not required to book a training. You can walk through a quick online training here: https://learn.faro.com/course/view.php?id=1070. For additional information on setup, scanning, and general App functionality please see the Flatness Check User Documentation.
