FARO Sphere
Sphere
Floorplan Overlay in FARO Flatness Check
Flatness Check allows you to quickly overlay a floor plan to your analysis results directly in the app. This can be a tremendous help to understand if a dip or bulge is in a critical area like a glass wall. Visualizing this together through AR, enables the site crew to act immediately.
The video below is walking you through the simple steps of aligning the floor plan to your analysis.
  • Bring a pdf, jpg or png of your floor plan to your iPad via iCloud or other solutions.
  • Its recommended using two opposite clearly identifiable points for the overlay (like wall edges or columns) to achieve a good overlay result.
  • Was this article helpful?
