Release Notes for FARO Zone 3D
This article lists the Release Notes for each version of FARO Zone 3D Software to date. The current version release notes are displayed at the top of the article. Previous revisions are contained in expanding sections below.
Navigating this article:
- Use the Table of Contents block in the upper right hand of this article to jump to a release.
- You can expand a version section by clicking the + button
- To search all versions, click the Expand All Versions button and then use the Ctrl+f search feature in your browser. Sections must be “expanded” to be searched.
FARO Zone 3D 2026.10.1007 Release Notes - October 2026
- Image Import – TIFF large image tiling crash
- Azure maps not updating location
FARO Zone 3D 2026.9.908 Release Notes - September 2026
- Model UI - resize tool for model customization
- Skinned model - mirror options to motions
- Skinned model - attached objects improvements
- Point Cloud interactive registration updates
- Zone recording - long recordings crash with no error fix
- File reference objects - Zone2Go toggles, layer separation
- Generic vehicles category added
- DWG/DXF import and export fixes
- Experimental - new trajectory cone tool
- Multi-language support for Zone2Go
Bug Fixes
- FZ3-13720 Trajectory Attachment - Rename - Impact to Entry
- FZ3-13719 Trajectory Attachment - Allow snapping to geometry
- FZ3-13718 Window - Grips - Height grip is moving the camera when adjusted
- FZ3-13713 Language support Z2G
- FZ3-13710 CADLib - invalid entity error on export dxf. Display native error. Add option to rename bad symbol
- FZ3-13709 Print PDF issue - Russ project - vehicles obscured by image
- FZ3-13707 Clipping Box - Setup Default to Transparent
- FZ3-13705 Trajectory Attachment - Flip default for Z-Plane
- FZ3-13701 Attach Trajectory / Draw Trajectory - Default trajectory to a "Trajectory" layer
- FZ3-13700 Trajectory Attachment - Changing units in ribbon not effecting dimensions
- FZ3-13698 Trajectory Attach Tool - Add border around planes so they show in ortho view
- FZ3-13697 Attach Trajectory Cone - Align to model rather than scene
- FZ3-13696 Camera - Scene Nav - Make sure left mouse is enabled by default
- FZ3-13695 Attach Trajectory Cone - Give the green grips a little length to begin with
- FZ3-13684 Wout DWG issue with color, Text, Filled rect and poly
- FZ3-13680 Model Resize - Icons
- FZ3-13678 Pano Recording Progress - add recording settings to display.
- FZ3-13677 New SceneAPI 2.20.16572 integration and testing
- FZ3-13676 new Docs folder/move. Make sure empty, investigate adding FARO Zone
- FZ3-13673 ZOne Pano recording, investigate massive slow down that occurs during long recording
- FZ3-13672 File Reference - Add toggles for layers into ribbon if exists
- FZ3-13671 File Reference - Add to different sublayers based on type of file
- FZ3-13669 File References - Add toggle visibility of layers for different types of file reference
- FZ3-13668 Preferences - rename SCENE Navigation - Disable Left Mouse Button Navigation
- FZ3-13667 File Reference - Move buttons into a table
- FZ3-13666 File Reference - Add description
- FZ3-13663 LP Import. set mirrors and chrome with reflection properites automaticaly
- FZ3-13662 File Reference - In layer manager refer to different file references with their file type
- FZ3-13661 File Reference - Copy SiteScape colors and icons
- FZ3-13660 File Reference - Setup different materials for each file type
- FZ3-13659 File Reference - Z2G - Fix Z2G to enable showing more than one file referenced file
- FZ3-13656 Zone recording pano animations with point clouds that are LONG... crash... with no error
- FZ3-13654 Customer: FotoPoints messages missing
- FZ3-13652 EDR auto parsing issue: 2025 Ford Explorer Police
- FZ3-13647 Model Resize - Add Track Width Direction Mode
- FZ3-13646 Model Resize - Add Wheelbase option
- FZ3-13645 Model Resize - Keep the model name the same add resized to end
- FZ3-13644 Model Resize - Add Undo Option to left Panel
- FZ3-13643 Model - Add option to snap beneath the wheel center
- FZ3-13642 Scalebar - Do not allow on _Forms layer due to how forms scales differently
- FZ3-13641 Lensflare refinements for HDR
- FZ3-13638 HDR Skytexture not loading properly
- FZ3-13636 Z2G Exports, Some objects are not exporting PBR properly (Polyline, arc, sphere so far)
- FZ3-13635 FotoPoints: inconsistent scaling messages after RTK check
- FZ3-13634 SiteScape - Use thumbnail with all file import types
- FZ3-13632 Quick Report - Forms Layer - Scalebar Visibility Issue
- FZ3-13631 Light CDT - Look into possible save/load issue where lights disappear
- FZ3-13626 Model Resize - Add Cancel Button to left panel
- FZ3-13625 Model Resize - Make sure grips are on the corners of the rectangles
- FZ3-13624 Resize Model - See if you can get the grips to flips side based on the camera
- FZ3-13623 Model Resize - Use multi-state buttons for the direction
- FZ3-13622 Resize Model - Add more labels to scene
- FZ3-13621 Resize Model - Remove radius have length work like width and height with tall skinny rectangle
- FZ3-13620 Resize Model - Default Length - Use model size rather than wheel base
- FZ3-13619 Resize Model - Change Resize Zone grips to be arrows
- FZ3-13618 Resize Model - Remove resize width from Left Panel
- FZ3-13617 Resize Model - Make default size Smaller
- FZ3-13616 Animation Path - Auto smooth not updating path
- FZ3-13615 Animation Path - Skinned - Auto Smoothing - Add to UI
- FZ3-13614 Animation Path - Standard - Auto Smoothing - Look into issues
- FZ3-13613 z2g Implement Grass
- FZ3-13611 zone interactive registration, group moving
- FZ3-13608 Left Panel - Setup file reference boxes to have a maximum width
- FZ3-13607 Skinned Model - Attached Models - Something wrong
- FZ3-13605 Skinned Model - add mirror option to motions
- FZ3-13604 FotoPoints "curvature" issue: from customer
- FZ3-13603 FotoPoints: video mode "ghost points" issue
- FZ3-13597 File Reference - UI File Box - setup for a tool tip on hover showing filename
- FZ3-13596 Scene Navigation - with left mouse disabled re-enable auto selection rectangle draw
- FZ3-13595 Model UI - Add resize to the left panel quick options
FARO Zone 3D 2026.7.727 Release Notes - July 2026
- .NET runtime fix
FARO Zone 3D 2026.7.713 Release Notes - July 2026
- NET 10 conversion
- Azure maps replaces Bing maps
- Zone 2 Go - many updates and fixes
- AutoStats Lite update 2026 models
- Fotopoints RTK drone detection
- Layer manager – sorting A-Z, index
- Experimental – Model resizing (length – width – height)
- EDR Steering input understeer effect, KEP nudging
- Trajectory cone attachment tool
- CDT import description cutoff when many space
Bug Fixes
- FZ3-13521 Add SaveAs to quickbar
- FZ3-13518 Admin Templates Path - if set override the normal Templates path
- FZ3-12572 Allow Zip and Share of .far - no messaging needed - Always exists
- FZ3-13498 Amplitude - Add scanner type for point clouds
- FZ3-13448 AutoStats Lite - Update 2026
- FZ3-13463 Axon - add a hint to the download error "check download permissions. Try setting to Any file"
- FZ3-13452 Axon - investigate Anthony Drabik download error that happens for all downloads. Upload works
- FZ3-13501 Azure Map Support - research
- FZ3-13440 Cabinet - Error with rendering the knobs
- FZ3-13423 Docs: add Function Key shortcuts
- FZ3-12983 DZR - HDR Enviro - iteration 1
- FZ3-12981 DZR - HDR Lighting - iteration 1
- FZ3-13469 EDR animation path: SmoothCurves has no effects on the last KEP
- FZ3-13553 EDR Report button crashed Zone
- FZ3-13221 EDR steering input implementation refactor
- FZ3-13484 EDR steering input refactor: understeer effect
- FZ3-13583 Fence good neigbor not in Draw dropdowns options
- FZ3-13516 Fence Post horizontal boards can't change color
- FZ3-13456 Fix 2D favorites pathing issues
- FZ3-13522 Fix webinar button on the start page - it was showing even when expiration hit
- FZ3-13436 FotoPoints RTK drone detection
- FZ3-13486 Hook up new Wout CADLib 10.0 library and test
- FZ3-13360 Image - border size / color not updating from HUD.
- FZ3-13462 Image Cleanout - cancel progress not closing the bar - not repeatable
- FZ3-13298 Layer Mgr - A-Z sort - Andy Rich
- FZ3-13585 Layer Mgr - sort by index, UI/UX
- FZ3-13514 Make a Generic or Basics vehicle category and move Generics to it
- FZ3-13569 Model - Resize - When changing mode update the grips
- FZ3-13543 Model - Zone Based Resizer
- FZ3-13562 Model Resize - Add in width and height mode
- FZ3-13568 Model Resize - Ghosts - Make sure it's in the right units
- FZ3-13586 Momentum - Not loading properly
- FZ3-13421 NET 10 update
- FZ3-13570 New Icons / updates
- FZ3-13409 Nudges for fixed KEP length
- FZ3-13496 Open Source licenses PDF update
- FZ3-13433 Ortho density map - applying color to transparent bitmap
- FZ3-13561 PdfiumViewer - convert net10
- FZ3-13525 PhotoCore RTK georeference support
- FZ3-13554 Point - Grip Move is moving with the scene navigation mode
- FZ3-13353 Scene Navigation - Add preference to disable left mouse in scene nav
- FZ3-13549 Skinned Model - Attachment - Show the axis for the node the model is attached to
- FZ3-13551 Skinned Model - Model Attachment - Add color to the XYZ columns to be the same as the axis
- FZ3-13449 SphereXGZ2G Utlity p2
- FZ3-13519 Templates when Enterprise - options to filter out subfolders.
- FZ3-13453 Toast message testing for PC imports
- FZ3-13468 Trajectory - Body Attachment - Not working see Russ's scene
- FZ3-13546 Trajectory Attachment - Add space
- FZ3-13548 Trajectory Attachment - Flip Direction row to have the normal face the other direction
- FZ3-13544 Trajectory Attachment - Offset text or grip so they don't overlap
- FZ3-13547 Trajectory Attachment - Rename "Axis" to "Plane" Rename "Scale" to "Size"
- FZ3-13545 Trajectory Attachment - Switch the color box to a solid color
- FZ3-13503 Trajectory Cone - Body - Attach Tool - Part 2
- FZ3-13471 Trajectory Cone - Look into multiple attachments to the same skinned models save / load
- FZ3-13473 Trajectory Cone - Report - Allow setting the different views (Snapshot, Side, Top)
- FZ3-13242 Trajectory Report - add image to add additional images to the report (FAE customer request)
- FZ3-13517 VADMV - Templates - Add Admin Templates Path to admin settings
- FZ3-13459 z2g - export panos without webshare p2
- FZ3-13431 z2g - image annotations, make outline border to contrast better
- FZ3-13430 z2g- camera out of bounding box on mini map, handle gracefully
- FZ3-13332 Z2G can zoom off to infinity with center mouse.
- FZ3-13417 Z2G Layers support
- FZ3-13509 z2g particles not working
- FZ3-13557 z2g point cloud LOD- tweak lod threshold
- FZ3-13428 z2g Save sparse point cloud, optimization. save leafs directly vs recreating them....
- FZ3-13506 Z2Go - F10 issue - menu activating
- FZ3-13457 Z2Go Export - Detect and update binaries
- FZ3-13374 Z2Go Export - Launch Zone2Go needs a good tooltip
- FZ3-13527 Zone- HDR Point CLoud issue
- FZ3-13520 Zone- sniper mode
- FZ3-13397 zone, virtual depth mode, have option for larger point size to occlude more
- FZ3-13497 Templates - Icon.PNG .. + documentation. Hover for folder - documentation
- FZ3-13492 CDT import cutting off descriptions with many spaces
- FZ3-13491 z2g export - have option for lower rez panos (aka 4k/8k) using internal (NOT WEBSHARE) method
- FZ3-13488 Trajectory Cone - Attachment tool Start
- FZ3-13483 zone- calculate pc bounding box bug
- FZ3-13477 z2g export add option to 'not include' specific scans for export
- FZ3-13476 new SceneAPI integeration.
- FZ3-13474 Axon - download error message - don't show mattmo's exception
- FZ3-13439 Add Zone2Go to favorites - svg does not convert to png - blank button- Aryck
- FZ3-13413 Z2G - Sniper Mode
FARO Zone 3D 2026.4.0421 Patch Release Notes - April 2026
- Registration quality report updates
- Zone 2 Go 2.0 – all support documents exporting, warning if files not found
- Ortho density map color updates
- F1 help panel launch
- F12 toggle point cloud visibility no HUD
FARO Zone 3D 2026.4.0414 Release Notes - April 2026
What’s new for 2026
Zone 2 Go 2.0 – easily create and share deliverables
- Project explorer organizes all case documentation
- Full diagrams and point clouds
- Reports
- Scaled orthographic images
- Animations
- Fly Through Videos
Blink with Stream Registration
- Blink integration delivers a field to finish solution for public safety insights
EDR Auto Import
- Auto import introduces an automated workflow for creating vehicle animations from EDR Reports
- Auto-import available for BOSCH, Tesla, and GIT
FotoPoints RTK Support
- Support for Skydio and DJI drones
- Produces highly accurate, georeferenced point clouds
Evidence Markers 2.0
- Multiple attachments
- Four-sided evidence markers to improve visibility
Ortho Density Improvements
- Preview image-based selections instead of text
- All pre-processed at once for easy selection and understanding of which will be best for your scene
- No more guesswork
Quick Report Tool
- Ensures all elements get placed in the working environment – and ultimately the report
Point Cloud Improvements
- Registration Report Colors option: shows the quality of registration
- Point Super-Sampling for crisper edges
SiteScape Import Returns
- Great first responder solution – first on site, first to capture and preserve evidence
SCENE SmartNav
- Navigation mode to match experience in SCENE software
FARO Zone 3D 2025.14.0219 Release Notes - February 2026
Latest Release Quick Review
- Large image memory issue fix
- Progress spinner dialog no longer blocks other programs
- Fixed Loading .fzpc files - the progress spinner did not close when finished
- Fixed Sometimes exporting to Zone2go caused Zone3D to hang
Previous Updates
Improvements to:
- Legend from Evidence Placard Tool
- Quick Report
- FotoPoints
- Image Clean-Out
Evidence Placards
- Attach multiple files to an evidence placard
- Works with Layer Report
Video Creation Library
- Faster recording times
- Large file 360 spatial support (Effective Reality Panoramic Animations)
Prime Workflow System
- https://farotechnologies.mcoutput.com/faro_zone_3d_help/en-us/FZ3_UG_EN.htm#Home/Workflow_Dialog.htm
Favorites Toolbars
Quick Report Tool
Ortho Density Map Tool
Evidence placards
FotoPoints RTK
Bug Fixes
- FZ3-12975 fixed drawing - bogus sign object render error
- FZ3-12950 Legend - double click or space bar to copy and paste. It should clear out description
- FZ3-12951 Legend Tool issues
- FZ3-13008 Legend - Description refresh issue
- FZ3-12979 Witness Body - Fix the transparency issue
- FZ3-12847 Print - Report Form - If form layer is hidden it still uses it in the print preview.
- FZ3-12932 Evidence Marker - Swap Icon to report icon
- FZ3-12912 Skinned Model - Add name field to UI
- FZ3-12947 Quick Report - North Arrow - Doubling North arrow options
- FZ3-13011 Scalebar - Highlight 3D Issue
- FZ3-12909 Animation Path - Lights issues
- FZ3-12948 Quick Report - 2D Only - Not refreshing for print form
- FZ3-12943 Quick Report - When you place do a zoom all
- FZ3-12964 New Scene API integration test
- FZ3-12914 Witness body color recognize transparency
- FZ3-12866 Point Cloud - Connection Report not centering properly
- FZ3-12933 Animation Path - UI - Skid Marks - Update UI for skids and tracks in separate collapsible
- FZ3-12944 Road Tool dirt road - single lane UI/Arc and crash
- FZ3-12945 Road Arc - Zone 3D in 2D /2D mode unhandled exception HUD ugly
- FZ3-12949 FotoPoints: Dynamic down-sampling for video mode
- FZ3-12872 EDR Auto import: Support GIT pdf
- FZ3-12931 EDR: Pre-crash only message box updates
- FZ3-12952 EDR Auto Import: Experimental plus PDF samples
- FZ3-12938 FotoPoints: 360 pano image support
- FZ3-12995 Layer Move - multi select and move in a block, and retain selections
- FZ3-12899 Thread safe manager - Toaster for spinners
- FZ3-12879 Image Cleanout bug - Undo messes out
- FZ3-12880 Image Cleanout bug - selection
- FZ3-12986 Workflows - cleanups and DLC
- FZ3-13006 MS PDF Print issue. Dashed Line
- FZ3-13009 SiteScape - experimental
- FZ3-13010 Vehicle DB search draw issues
- FZ3-12958 Particle Effects - Fire - UI - Needs Cleaning Up
- FZ3-12976 re-order n arrow 3D / 2D
- FZ3-13000 Lights Models - find / fix models mesh issues
- FZ3-12998 FotoPoints: Load CPE spinner issue
- FZ3-13013 EDR PDF sample files access
- FZ3-12990 EDR Auto Import: Bosch pdf testing
FARO Zone 3D 2025.11.1120 Release Notes - November 2025
Improvements to:
- Quick Report
- FotoPoints
- Image Clean-Out
- New! EXPERIMENTAL (See Notes on Experimental Ribbon)
- Zone2Go 2.0 (Shareable Presentation Tool and Digital Case File)
- EDR Auto Import
Bug Fixes
FARO Zone 3D 2025.10.1016 Release Notes - October 2025
Hot Patch
- Snapping issues 2D mode fix
- PTS import issue with non-standard formats fix
- Cabinet UI fix
FARO Zone 3D 2025.9.915 Release Notes - September 2025
What's New
Important bug fixes. FARO Zone 3D is now accessed via InTouch. This allows for easier installations and regular updates.
Important Fixes Quick Review
- 3D Warehouse Import
- Bing Map Load
- CDT Units Issue
- Workflow/Favs 2D/3D DLC
- Skinned Model print render on animation paths
- Skinned Model paths time/distance markers
- Large jpg file support
- EDR Data – Apply to articulated vehicles (only affects the truck or first vehicle in line, the rest follow)
InTouch
- FARO Zone 3D will now use the FARO InTouch installation and update center.
Evidence
What’s New (in 2025)
Favorites Toolbars
Quick Report Tool
Evidence Placards
FotoPoints RTK
Bug Fixes
- FZ3-12816 FotoPoints: Skydio X10 image set issue
- FZ3-12815 Rotating Progress Popup - Object Disposed Exception
- FZ3-12814 Layer Report - extending the drawing area to fill the page in legal rather than letter
- FZ3-12813 Skinned Model - Animation Path - Not appearing in Print
- FZ3-12811 Video Recording - Panoramic Videos - Write directly to video
- FZ3-12809 Mass Zone - Add Record and Record Pano to MZU Control Panel
- FZ3-12808 Workflow / Favs translations out/in
- FZ3-12806 Zone 3D beta - ani path 360 issues/testing
- FZ3-12797 3D Warehouse SKP file loading issue
- FZ3-12796 Video Recording - Write frames directly to video during creation
- FZ3-12795 UI - Table - Evidence marker Attached Files - Table is setting the spacing wrong
- FZ3-12793 CDT - Altus RAW Meter unit not converting correctly
- FZ3-12789 Change MP4 Spatial Injector To Support Huge Files
- FZ3-12787 EDR PDF auto import: PDF page selection UI
- FZ3-12785 Snapshot - 3D - Current View - Taking full screen not the current view
- FZ3-12782 Translations 25.8.xxx
- FZ3-12781 Favorites 2D - reset issues
- FZ3-12780 Print Snapshot - With Form Not rendering properly
- FZ3-12778 Fix Short Video File Creation Issue in MP4DotNet
- FZ3-12776 Evidence Marker - Multi-Select files during attach
- FZ3-12775 Evidence Marker - Add Option to ignore Shadows
- FZ3-12774 Mouse Aware ground-based positions
- FZ3-12773 HUD - Right Align - Play Button issue
- FZ3-12772 Canvas resize causes error.
- FZ3-12771 Legend Tool - Update Issue GDI
- FZ3-12770 Evidence Marker - Report - Make sure it handles multiple file references
- FZ3-12769 Evidence Markers - Default to 4 sided
- FZ3-12768 Evidence Marker - Allow adding multiple referenced files
- FZ3-12767 Video Recording - Panoramic Videos transition to new in-house video library
- FZ3-12762 Bing Map account updated
- FZ3-12760 Select image after placed from Ortho Density Map
- FZ3-12756 UI - Right Align - Convert Panel going to left
- FZ3-12755 UI - Right Align - Mouse Dead space issue
- FZ3-12749 Favorites - Add highlight to used commands
- FZ3-12747 Quick Report - when opening Quick Report stuff isn't being placed automatically
- FZ3-12746 Quick Report - going to 2D the screen is black
- FZ3-12745 Quick Report - North arrow will disappear
- FZ3-12740 2D - HUD Align Right - Issue with initial draw size
- FZ3-12738 HUD - Right Align - Issue with collapsible
- FZ3-12737 Quick Report - 2D North Arrows
- FZ3-12736 Quick Report - Tiled Image - Throws an error if you start a quick report looking for a north arrow
- FZ3-12733 Quick Report - first time does not include scalebar, north arrow in the extents
- FZ3-12732 For Patch - Quick bubble label HUD
- FZ3-12731 For Patch - Quick Report - North arrow and scalebar, and legend to in Save Load
- FZ3-12730 EDR animation HUD location issue
- FZ3-12724 Favorites - move left/right not working on this button - see attachment
- FZ3-12707 Vehicle DB, clean make given for year.
- FZ3-12705 Legend - Bubble Label - Add option to use Bubble Label items as evidence markers in legend tool
- FZ3-12703 Animation Recording - Switch over to new in-house video library
- FZ3-12702 Quick Report - can't erase the Scalebar. Users might try to delete a North arrow or scale bar or legend.
- FZ3-12701 Quick Report - Layer with bad extents
- FZ3-12700 Quick Report - Create Toggle for legend
- FZ3-12690 Point UI - can't change Point type on-the-fly when placing a point. dialog has to be closed and reopened to see new point style selection.
- FZ3-12684 Print Snapshot - Doesn't include the print form like the normal print
- FZ3-12641 Ortho Density Map form - make image zoomable like in Image Cleanout
- FZ3-12604 Report - Volumetric Crush Report
- FZ3-12579 Animation Path - Skinned Models - Cannot create a time distance animation report from a body walking animation path
- FZ3-12578 Report Center - Damage Report, rename to "Crush Damage Report"
- FZ3-12577 Report Center - Animation Report should be called "Animation Time Distance Report"
- FZ3-12534 Parking Lot - Change Line color not updating to black in 3D when reset
- FZ3-12521 Structure - All Material - Always resets back to basic material
- FZ3-12517 Clipping Box - UI - Add Visible checkbox to left panel
- FZ3-12499 Animation Camera - Target Path UI - Should have an option for select primary path
- FZ3-12466 Snapping - Perpendicular - Investigate the AllowSnap property
- FZ3-12456 create report to show PC scan connections
FARO Zone 3D 2025.7.0707 Release Notes - July 2025
What's New
Move right into Prime Workflows just by clicking on the Start page “Pick Data Type” picture. Switch evidence placard styles from two-sided folded version to four-sided tent versions. Updated Ortho Density Map interface making it easy to pick the look you want. FotoPoints can process Skydio and DJI photos embedded with RTK data for better precision.
Favorites Toolbars
https://farotechnologies.mcoutput.com/faro_zone_3d_help/en-us/FZ3_UG_EN.htm#Home/Favorites.htm
Quick Report Tool
Evidence placards
Bug Fixes
- FZ3-12686 SceneAPI Blink registration testing
- FZ3-12683 Workflow - Add option to open a workflow from a workflow
- FZ3-12682 Vehicle Specs 2025 update
- FZ3-12681 Clipping Box - Add one click draw
- FZ3-12678 Point Cloud - Allow setting rotation, origin, Point
- FZ3-12676 Point Cloud Rotate - Hold down shift
- FZ3-12675 Move Grip - Elevation - Add vertical line connecting the sections
- FZ3-12672 Add to Favorites - Symbol Search with North as a parameter (use what is in the search box if open)
- FZ3-12669 Favorites - Forms menu does not pop up from Favorites...only works in 3D
- FZ3-12640 Animation Path - Damage - Jeep Cherokee 2019 - Damage while on an animation path is hiding parts that it should not
- FZ3-12625 Photocore (FotoPoints) library update - Including new RTK report
- FZ3-12622 Maui FotoPoints Scene integration
- FZ3-12617 Favorites - Ability to call a specific workflow
- FZ3-12651 Forms/Templates Dropdown - Allow adding to favorites like the structures drop down
- FZ3-12650 Google image selected - the sat button on HUD has a different view than the sat button on Ribbon
- FZ3-12644 Workflow - Instructions UI Edit - Swap out movie Icon
- FZ3-12639 Workflows - Add a section for icons for primary workflows
- FZ3-12638 Vehicle Specs Database - Coupe/Mini-Van - When placed seems to have a SDX 2D draw issue
- FZ3-12636 Ortho Density Map UI Rework - Option to make the background of an ortho image and/or density map transparent?
- FZ3-12635 Ortho Density Map is called CTVImage in Layer Manager. Please change to "Ortho Density Map".
- FZ3-12634 Spelling Mistakes - Analyzing have been misspelled in some message boxes....”Analysing”, Please change the "s" to a "z"
- FZ3-12633 SiteScape - Import - Delete existing point cloud if importing into a project that already has one
- FZ3-12628 Evidence Makers - Add 4-Sided Style
- FZ3-12616 Favorites Toolbar - ability to add specific form to command Ribbon
- FZ3-12615 Workflows - add option to open a specific Favorites toolbar
- FZ3-12587 UI - Add preference to move the Left panel HUD to the right side of the screen
- FZ3-12575 Workflows - Need a better icon for commands placed in workflow that do not have icons, like "Pick Z Elevation Point"
- FZ3-12568 Zscp SiteScape file format - support drag drop
- FZ3-12498 Fillet - Doing a fillet on the existing line does not take on the line properties
- FZ3-12480 CDT - Arrow key thru formats should reload and populate grid - great for testing and finding the best format
- FZ3-12623 Emlib Reach RTK format added to CDT
- FZ3-12606 Blood Spatter - Report Changes
- FZ3-12605 Site Scape - Import - PC Import Button
- FZ3-12602 Snap to locked layer - lock CDT but would still like to snap to points
- FZ3-12601 MZU- If user hits "MassZone Report" when they have not run an MZU prediction yet. gets a Null Reference error. Report Button should be disabled or give user prompt when they click it and MZU run data is not generated yet
- FZ3-12598 MAUI FotoPoints review
- FZ3-12597 MAUI: GCP UI
- FZ3-12596 File Reference - Add Pole and outline colors
- FZ3-12595 File Reference - Pole - Allow negative offset
- FZ3-12594 ZoneScape - File Reference - Icon Offset should be small
- FZ3-12593 ZoneScape - File Reference - Z-Offset should be 0
- FZ3-12592 ZoneScape - Move the images into the project folder during import
- FZ3-12591 Integrate GPS into SiteScape
- FZ3-12586 SceneAPI Beta integration and testing
- FZ3-12583 Tiled Image - deleting tiles should recalculate bounds
- FZ3-12581 Ortho Density Map - Height Heat Map options
- FZ3-12574 Workflows - Printed out workflows - the Title lines are not bolded
- FZ3-12573 Workflows - allow a web link to be added as a line in the workflow (i.e. a link to SiteScape download)
- FZ3-12571 Multi-Window - Force it to be only 2D window
- FZ3-12562 ZoneScape - Set orientation to facing
- FZ3-12532 Camera - Orbit - If the orbit mouse down does not detect something to orbit it does weird things
- FZ3-12514 Tiled Image - Multi Select - Add merge option to multiselect
- FZ3-12490 Dimension Line - Draw - With Slide the draw sets one of the points at zero
- FZ3-12483 Evidence Marker - Drawing - Make sure to check if evidence markers already exist instead of just assuming restart at A on a loaded scene
- FZ3-12420 Animation Path with MZU options show blank bar until prediction is performed
- FZ3-12588 ZoneScape - Setup Auto Import Form - Start
- FZ3-12570 Duplicate - File Reference - Copy/Paste in 3D is working oddly
- FZ3-12567 ZoneScape - File Reference - Default Unlit to On
- FZ3-12566 ZoneScape - File Reference - turn off pole by default
- FZ3-12565 ZoneScape - Force using a project folder and create the Point Cloud in
- FZ3-12564 File Reference - Setup outline and pole properties to be global
- FZ3-12563 File Reference - Set color to be global for all references of a specific file type - ex Photos
- FZ3-12561 File Reference - Move Icon closer to the background with a small size
- FZ3-12560 ZoneScape - File Reference - Default to a light green
- FZ3-12558 File Reference Object - Add in option for a vertical pole
- FZ3-12557 File Reference Object - Pitch == 90 and circle mode do not work properly
- FZ3-12556 ZoneScape - Use file reference icons for images - Set them to be standing up
- FZ3-12555 FotoPoints: New Folder button not showing
- FZ3-12554 FotoPoints: GCP file format import issue
- FZ3-12552 Backups Manager - add options in the hamburger menu
- FZ3-12551 Layer Mgr - When selecting multiple objects in the layer mgr, show them selected on screen - currently only one selects on screen
- FZ3-12548 Sketchup SDK 2025
- FZ3-12545 Backup Mgr - better exit message box if file previewed but not restored
- FZ3-12542 Image Cleanout - better exit message when image has not been saved
- FZ3-12539 GeoTIFF import panel to tiles
- FZ3-12533 LEGEND UI HUD - EXPERIMENTAL show control
- FZ3-12530 Ortho-density save, suggest file name
- FZ3-12524 Animation - Recording - From Recording is not starting at T==0
- FZ3-12520 Backup Mgr - Show fzproj size in the grid - showing 0 Bytes now
- FZ3-12511 Quick Tab - 2D add map, remove Streets
- FZ3-12491 Point Cloud Scene - Enable point clouds to work with the 3pnt align and other movement tools
FARO Zone 3D 2025.4.0416 Release Notes - April 2025
What's New
This is the first patch release of Zone Expert/Expert Plus 2025 and includes some exciting updates to the Image Clean-Out tool and Backup Manager and more great updates.
- Image Clean-Out (watch movie)
https://faroassist.com/media/339094b5-ac57-4e86-b773-9af09cb85bfd/ - Back-Ups Manager (watch movie)
https://faroassist.com/media/dda52589-3737-4368-b582-66b28261d402/
Bug Fixes
- FZ3-12459 Tiled Image not detecting empty tiles
- FZ3-12494 Georeferenced Tiled Images - need to be able to remove empty tiles
- FZ3-12481 FotoPoints ortho image multiple panels issue
- FZ3-12545 Backups Manager - better exit message box if file previewed but not restored
- FZ3-12520 Backups Manager - Show fzproj size in the grid - showing 0 Bytes now
- FZ3-12518 Backups Manager - Sort by name instead of date. Name will always have a date stamp
- FZ3-12505 Backups Manager popup message when hovered over a file - click to preview
- FZ3-12495 Do not Save Backup after a Tiled Image is finished being created. Very annoying
- FZ3-12551 Layer Mgr. - When selecting multiple objects in the layer mgr. show them selected on screen - currently only one selects on screen
- FZ3-12516 Layer Mgr. - r-click, new layer, + disappears
- FZ3-12542 Image Cleanout - better exit message when image hasn't been saved
- FZ3-12529 Image cleanout Workflow - blank lines
- FZ3-12453 Image cleanout tool - implement new vehicle profile detection
- FZ3-12508 Research - Image Cleanout - Flood Select to Not Require Thresholding
- FZ3-12471 Parking lot HUD. down arrow stall width to 0 causes massive hangup
- FZ3-12468 Parking Lot line type- Default Lines to Black instead of white
- FZ3-12548 Sketchup SDK 2025 Update
- FZ3-12546 Fix Major Update dynamic test of License
- FZ3-12504 Update patch user experience. Force shutdown
- FZ3-12474 Provisional Key message going behind when I launched 2024
- FZ3-12444 Clipping Box - Default clipping box to hide outside on first box - Don't hide points during draw
- FZ3-12438 Point Cloud Tools - Top Bar Create 2D View not opening the workflow
- FZ3-12415 3D Volume Crush - Setup error messages that are specific to missing steps
- FZ3-12523 PC Lighting bug. global lighting was overwriting alpha value in pc
- FZ3-12513 Investigate and improve memory usage while navigating tiled images in Zone
- FZ3-12503 Match text with arrow - it shouldn't move the position of the arrow.
- FZ3-12492 FotoPoints bodycam exploring task
- FZ3-12489 704 Placard - Sizing issue in 2D with letters
- FZ3-12488 workflow dlc updates
- FZ3-12476 EDR: Yaw rate issue
- FZ3-12462 Evidence Marker - Add an option to create legend to the evidence marker UI
- FZ3-12461 Legend - Setup orientation values to increment by 45 on the major and by 1 on minor values
FARO Zone 3D 2025.3.0306 Release Notes - March 2025
Upgrade – Now available, Zone 2025 Expert and Expert Plus!
Zone Expert gives you all the tools you need to create reports, compelling courtroom presentations (animations and flythroughs), import point cloud data, create point cloud and ortho images from photos and videos, and analyze data using crime and crash power tools.
- Automatic Legend Tool
- Advanced Image Clean-Out with A.I. Vehicle Detection
- Create an Ortho Density Map from you Point Cloud
Zone Expert Plus gives you all the features of Zone Expert along with a powerful set of new features for registering and working with point clouds that makes Zone the only product you need for working with your FARO scan data.
- Point Cloud Auto and Visual Registration (works with Stream)
- Point Cloud Registration Report
- Point Cloud Clean-Up
- Point Cloud Shadow Casting
- Point Cloud Dynamic Point Size
- Crush Zone (Volumetric Crush Analysis) from point cloud data
Bug Fixes
- FZ3-12465 PC Visual Registration- highlight/differentiate the scans in scan list that are not locked/connected
- FZ3-12460 No Shadows with XL Lights causes error
- FZ3-12448 PC Shadows animation recording crashes when not using follow cam
- FZ3-12446 Default Clipping box to clip exterior
- FZ3-12437 Axon message cut off. Add link to PDF docs
- FZ3-12436 Pano Views - allow greyscale view when no color data
- FZ3-12426 GeoTIFF - multiple panels importing issue
- FZ3-12418 Save As - Add Option For saving as a .fzproj.zip
- FZ3-12416 MassZone - Animation Path - Removing the animation path should also remove the model from MassZone
- FZ3-12414 Model - UI - Add 3D Crush to model UI if a point cloud in the scene
- FZ3-12412 FotoPoints Output folder message box hidden
- FZ3-12410 Image Cleanout - Polyline seems to be losing the point - cuts off selection
- FZ3-12409 Selected boxes not showing selecting - lost the dashed boundary
- FZ3-12406 Investigate PC Blur tool not working as expected
- FZ3-12399 Workflow - Look into word wrapping on cells
- FZ3-12398 Workflow - make the selected row blue color "lighter"
- FZ3-12397 Workflow - Only increment one row at a time. Don't skip to next main command
- FZ3-12394 Articulation - Having a Point Cloud Model in the chain causes problems
- FZ3-12393 Articulation - Shadows not working properly
- FZ3-12391 Snaps - Ortho 3D - Snapping in 3D from point to rectangle is being done in world space not screen
- FZ3-12388 Snaps - Ortho Snap - 2D if all snaps are turned off also turn off the ortho snap
- FZ3-12386 Crush zone in some cases it was including parts of the reference model mesh outside bounding box in volume calculations
- FZ3-12383 PC Registration - check destination folder is empty.
- FZ3-12381 Workflow - Allow right click on left panel actions
- FZ3-12380 Legend - Add Positioning controls to left panel HUD
- FZ3-12378 Security Halo crashes on scene with Point Cloud and Gap Fill
- FZ3-12375 Tiled Image - tile size option in settings. Default is 2K, 12K max
- FZ3-12374 Zip backup message should be clearer. Yes = Zip a backup, No = Do not make a backup at this time
- FZ3-12373 Zip & Share should not show a Backup message
- FZ3-12372 Tiled Image - make it work with new cleanout tool. Match Image Object functionality.
- FZ3-12371 Legend - Setup default padding for the symbol
- FZ3-12370 Point Clouds - Clipping Box - Create Profile line without points in the box hides the point cloud
- FZ3-12366 MZU - model - add to MZU, then add animation path causes issues
- FZ3-12364 drag and drop .fzproj.zip - allow it
- FZ3-12363 Fzproj save as defaults to .far
- FZ3-12352 Print Preview - Make the fields larger so the horizontal scroll bar isn't as useless
- FZ3-12344 Clipping Box - Profile Line - Add warning if clipping box doesn't contain points
- FZ3-12325 Ribbon 3D - Animation from stationary points - Problem closing message box
- FZ3-12312 Rectangle - Dashed Lines - Difference between the 2D render and the print preview
- FZ3-12300 Snaps ON pop up message is incorrect
- FZ3-12282 Image right click menu - Import/Export commands (Images and Satellite)
- FZ3-12266 GeoTIFF image set limit
FARO Zone 3D 2024.15.0310 Release Notes - March 2025
This release updates license checking functions to accommodate upgrades to the upcoming 2025 version.
FARO Zone 3D 2024.14.0211 Release Notes - February 2025
Bug Fixes
- FZ3-12333 Animation Path - UI - If item animated isn't a model (ex. Point cloud model) the paint options become problematic
- FZ3-12323 Translations - refresh
- FZ3-12322 Ribbon - Main Menu Dropdown - Remove Print Form
- FZ3-12315 Print - Add preference to show 2D or 3D dimensions on print preview
- FZ3-12303 Lines - Tiled Item - Setting spacing to zero crashes
- FZ3-12301 Point Cloud Model - Snap Terrain acting weird
- FZ3-12298 Legend - Add padding to the paragraph icon
- FZ3-12286 FotoPoints: Photogrammetry Report generation issue
- FZ3-12274 Curves - Convert To - Curbs - Not calculating the curve points properly
- FZ3-12262 Animation - Point Cloud Model - Undo not clearing out after undoing create
- FZ3-12260 Seat Leon 2020 model added
- FZ3-12070 FotoPoints: Scalebar page data binding issue
FARO Zone 3D 2024.13.0107 Release Notes - January 2025
Bug Fixes
- FZ3-12290 Fix PC Merge PC Visibility when selecting 3 points issue
- FZ3-12289 Fix PC Model Point Size issue
- FZ3-12288 Blood Spatter - Save Issue with JPEGs
- FZ3-12277 Skid Analysis tool - can't manually enter 2 rows - functionality used to be there
- FZ3-12276 Add scalebar to North arrows section in Zone 3D>Crash2D Symbols>North Arrow section (Site_2D)
- FZ3-12271 Cabinets - PBR Material - Countertop - Single Section
- FZ3-12270 Legend - UI - Add Refresh to the edit form
- FZ3-12269 Legend - Character Clipping
- FZ3-12104 Model - Elevation grip not turning off terrain follow
FARO Zone 3D 2024.11.1125 Release Notes - November 2024
Updates
New FotoPoints Engine
Match a selected model to the Vehicle Specs database.
- Faster point cloud generation.
- Can handle up to 1500 high-res drone images (need 8G GPU memory on your system).
- Improved image alignment.
- 200 million points max – SCENE API limitation.
Match Vehicles to Specs
- Select a vehicle currently on the diagram.
- Click on “Vehicle Specs” from the model properties panel under Tools or from the right click menu.
- The Vehicle Specs tool will automatically populate with the selected. Verify the make, model, and year are correct and finally click on “Apply and Close”.
Try out the new features on the Experimental ribbon. The new “Legend” tool will automatically build a legend and report from all evidence labeled with the Evidence Placard tool.
Experimental
Open the Notes on the Experimental ribbon:
Learn about and test new features currently in testing and development. Your feedback is very welcome!
- A.I. Image Clean-Out System (new!)
- Point Cloud Clean-Up Tool (updated!)
- Legend Tool
- Density-Based Ortho Image
- Stream Auto Point Cloud Registration
- Automatic and Visual Registration
- Crush Zone (Volumetric Crush)
SiteScape e57 Project Import
Find the Manual on how to import SiteScape e57 Project here.
Bug Fixes
- FZ3-12230 Image - Cleanout Tool
- FZ3-12228 Z2g without point cloud issue
- FZ3-12227 EDR speed rounding issue
- FZ3-12215 Dimension Line SL - Fix Percent Issue
- FZ3-12214 DLC Refresh 2024 final
- FZ3-12213 FotoPoints: Image limit message
- FZ3-12211 Audi A4 2019, Mazda CX3 2018
- FZ3-12210 Translations 24.11.xx
- FZ3-12209 New PhotoCore lib stress test
- FZ3-12207 EDR Hud issues when compact mode
- FZ3-12206 Axon - Arkansas Fish and Game
- FZ3-12205 Joana - UI review PC Cleanup
- FZ3-12204 Image Cleanout - UI and finalization
- FZ3-12197 oneway signs - fix outline
- FZ3-12196 current scanner visible during pano view. obstructing view
- FZ3-12194 PC Clean-up/Scanmap refinements pt2
- FZ3-12193 PC General Refinements pt2
- FZ3-12192 PC Shadows/Dyna Size refinements pt2
- FZ3-12188 PhotoCore lib upgrade
- FZ3-12169 Z2g: Legend support
- FZ3-12168 Z2g: Bubble Label link support
- FZ3-12191 PC Shadows/Dynamic refinements
- FZ3-12189 MS PDF Wall print issue
- FZ3-12186 investigate particle accel Z issue
- FZ3-12185 Animation Recording with PC Shadows crash
- FZ3-12181 Legend - Title Size not saving / loading
- FZ3-12178 Panoview, point clouds off, don't come back on sometimes when exiting Pano view
- FZ3-12177 PC Clean UP. 3D View selection options
- FZ3-12175 Symbol / AWS denied message
- FZ3-12167 Legend - Move into 2D
- FZ3-12163 Axon - Arkansas Fish and Game - not seeing download list - Increment
- FZ3-12160 Favorites - localizations
- FZ3-12159 Legend - Updates
- FZ3-12157 Experimental - orange dot on experimental commands
- FZ3-12156 Auto-Registration out-of-process p2
- FZ3-12155 PC Clean Up refinements
- FZ3-12154 Auto-Registration out-of-process p1
- FZ3-12153 Scan Map enhancements
- FZ3-12151 Airboat symbols
- FZ3-12137 Improve Inpainting for Car Cleanout Tool - increment
- FZ3-12136 Legend - Add header to the report
- FZ3-12118 4K testing Ortho Density Map
- FZ3-12117 4K testing PC Cleanup
- FFZ3-12076 FotoPoints: GBPD large project issues
- FZ3-11980 Tiled Images - Import Item to hidden layer it should turn back on
- FZ3-11806 FotoPoints: CPE to FLS
FARO Zone 3D 2024.10.1009 Release Notes - October 2024
Updates
Experimental
- Legend Tool
Last Release
Bug Fixes
- FZ3-12092 Anibuddies - Particle Effects - Need to reset when state changed
- FZ3-12086 Tiled Images - Fix lines in print
- FZ3-12083 Selecting Item - dual selection issue in list
- FZ3-12074 Translations German
- FZ3-12066 Axon - unnamed drawing, upload, name fz project
- FZ3-12065 PC Auto-Reg Visual Registration Load Scan data, make more granular progress
- FZ3-12063 Vehicle DB - search from model select
- FZ3-12062 PC Cleanup UI refactor p2
- FZ3-12061 UI - Frames per second showing not turning off in 2D canvas
- FZ3-12059 Install - Reboot - License Manager
- FZ3-12058 HUD / Line Types / consistency
- FZ3-12057 Start Page - click Update Available yellow image bring up Updates form FZ3-12055 DLC - update / paint
- FZ3-12053 Guardrail does not have a convert
- FZ3-12046 PC- Ortho Density Map, test CZD Room/body off center create map
- FZ3-12045 PC Merge, automatically close merge dialog and load LSProj when complete
- FZ3-12043 Test snapshot with Tiled Image and in Zone 2D build
- FZ3-12042 Snapshot tool crashes when image object in the drawing (in 2D view)
- FZ3-12041 PC Cleanup. Add checking for valid scanner data - Only works with raw "FARO SCAN DATA" not imported (fotopoints, fzpc, e57's etc...)
- FZ3-12040 UI Hi-res issues in AutoReg/Options/Radii FZ3-12039
- FARO Assist - Training playlist - fix pptx (pdf and image in assets)
- FZ3-12031 DLC Refresh 2024.8
- FZ3-12027 PC Auto-Registration Advanced Options UI and testing
- FZ3-12025 Video mode crash issue
- FZ3-12021 PC Cleanup - add checker box pattern for background option
- FZ3-12019 Image Scale issue
- FZ3-12018 Sphere object r-click menu
- FZ3-12017 EDR Dashboard preference issues
- FZ3-12003 Axon - Fix login experience
- FZ3-11997 FaroAssist display placeholder images if the tile image fails to load
- FZ3-11991 investigate importing multiple e57s from SiteScape and using Scene API automatic registration
- FZ3-11986 Nav Cube, highlight area for swapping Ortho views on cube
- FZ3-11979 Deleted - Polyline - Snap Perpendicular - Not getting double perpendicular snap
- FZ3-11977 Good Neighbor Fence - Not following curves properly for the boards
- FZ3-11976 preferences new color picker background 2d/3d
- FZ3-11946 Testing - Blood Spatter - Adjusting the position not effecting elevation
- FZ3-11925 Clipping Box Manager - Point Cloud Layer Invisible - Doesn't open manager
- FZ3-11848 AnimationPathUISkinned - Error
- FZ3-11836 Loading file with Legacy FZPC point cloud doesn't tell user if point cloud isn't found
- FZ3-11834 Animation Path - Context Menu - Follow terrain all - should be on the segment context menu
- FZ3-11827 VR- particles (fire, smoke etc) not working in VR after Optimizations
- FZ3-11488 DXF Import - add to Unit Scale form
FARO Zone 3D 2024.8.0821 Release Notes - August 2024
Updates
Click on the links to learn more!
Experimental
Bug Fixes
- FZ3-12006 Axon Connect - Add cancel sign in and async
- FZ3-11950 Axon request - upload a PDF (saved drawing)
- FZ3-11703 Axon 2.0 Implement Download
- FZ3-11802 Axon 2.0 Implement Upload
- FZ3-11964 Skid Analysis crash clicking thru controls
- FZ3-11795 Start Model placement, place first point, hit Delete to crash. fixed for Line command
- FZ3-11804 Animation Path - Swap animated Model - Crash
- FZ3-11794 start Line, select linetype, r-click on linetype crash
- FZ3-11777 Crash error exception form not resizing correctly
- FZ3-11984 One Step Visual Reg switching camera from ortho to perspective loses pc in view
- FZ3-11983 one step visual registration, only show grip for selected scan
- FZ3-12018 Sphere object r-click menu added
- FZ3-11998 Rectangle - 3pnt Draw - Spacebar repeat - not going back to 3pnt rectangle draw
- FZ3-11968 Arc line type menu corner selection only
- FZ3-11736 Arc - Arrow gap in line - Reduce to make sure there isn't a gap in 2D
- FZ3-12017 EDR Dashboard Preferences issues and updates
- FZ3-12011 Animation - Dashboard HUD - If velocity ON it shows acceleration even if acc. off
- FZ3-12010 Z2go: scanner data not exported if scanner not visible
- FZ3-11993 Auto Registration - help tips - match Scene
- FZ3-11990 Automatic Registration UI, default the radii to 75mm and/or 100mm radii.
- FZ3-11988 fix Zone 2D file filters - kill HD, Reality, Lsproj
- FZ3-11982 Preferences, color pick, z2g measure, reset wording
- FZ3-11963 Preferences - Add option to delete all preferences
- FZ3-11974 clean Language list prefs
- FZ3-11981 Skid Analysis - WB click then click any cell will make the upper left cell have focus,
- FZ3-11815 Animation Path – Ani-Buddies 2.0
- FZ3-11819 Animation - Attach 2 - Smoke does weird things
- FZ3-11818 Animated Bullet - Sync / Start Delay issue
- FZ3-11798 Animation Path - Skinned - No Impact Kep Settings - (In and Out KEP Settings)
- FZ3-11785 Animation Path - Context Menu - Remove KEP doesn't create an Undo Point
- FZ3-11778 Animation HUD - Dashboard HUD - Allow mixing EDR and normal paths HUD
- FZ3-11769 Animation Path - Replace Skinned Models - Motions xfer over after grip adjustment
- FZ3-11684 Animation - Skinned - Skinned models have an option for the animation HUD
- FZ3-11757 Animation HUD Display - Not expanding the length far enough with more than 4 cars
- FZ3-11735 Animation Path - Weird Error
- FZ3-11712 Animation Path - Door Opening - Last KEP Rotate Parts applied to previous path not the current kep on last KEP
- FZ3-11711 Anibuddies - Add Option for show
- FZ3-11710 Animation Path - Path + Skinned Model doesn't give Ani-Buddies Option
- FZ3-11786 Skinned Model - Animation Path - Null Reference Error
- FZ3-11789 Blank Animation HUD after Animation Stop pressed and reselect path.
- FZ3-11788 Workflow - Blood Spatter Workflow - Prints on two pages but doesn't need to
- FZ3-11787 Workflows - Create New - Adding North Arrow Symbol - Causes some sort of error
- FZ3-11884 Add Workflow Center to Search. Rename Workflows to Workflows Help Manual
- FZ3-11905 Workflows - translation - investigate
- FZ3-11820 Workflows - Setup print and export to csv on customer workflow UI
- FZ3-11635 Workflows - Create an ani-buddy workflow
- FZ3-11940 Favorites Toolbars filter out 3D toolbars for Zone 2D
- FZ3-11483 MZU Control Panel - resize form clips gear button
- FZ3-11841 MZU control panel - show status during prediction calculation only
- FZ3-11951 MZU Mirrors not working
- FZ3-11944 Z2g: Failed to create pano image error message
- FZ3-11929 Z2g: Scanner location offset in merged point cloud
- FZ3-11897 Z2g Marketing requests: enable 3D view and measurement
- FZ3-11943 Layer Manager. Toggle on/off needs zoom to refresh
- FZ3-11923 Ortho tool tips / state
- FZ3-11921 Dimension Angle - Custom Text - 2D Mode not working in release
- FZ3-11908 Grips-option to be more visible
- FZ3-11898 Scan Manager not populated if scanners are invisible
- FZ3-11896 Visual Registration visual enhancements
- FZ3-11895 Drag n Drop option for FLS folders/files in 1 Step Registration
- FZ3-11894 Print Form - If you print from a page other than the first it doesn't print the whole report
- FZ3-11890 Point Cloud - Registration Report
- FZ3-11771 Point Cloud - Snapping Adjustment
- FZ3-11800 New SD Card import/registration workflow?
- FZ3-11862 Romanian Road Signs
- FZ3-11857 Structure - corners are "chamfered in print
- FZ3-11854 Rotate 2D symbol in Zone 3D while placing. Not showing new rotation
- FZ3-11851 Vehicle Specs - vehicle box dimensions not matching HUD values
- FZ3-11850 Blood Spatter - CSV Export - drop IDs starting at zero unlike PDF report
- FZ3-11849 Preferences - scroll down a page then exit. You can never scroll to the top of that page again
- FZ3-11843 camaro - lights?
- FZ3-11840 pc merge UI, change labeling on primary/secondary fzpc stuff
- FZ3-11835 Label - Rounded Border and Facing Text issue
- FZ3-11833 Test Axon Auto Refresh Credentials
- FZ3-11831 DblClk to copy - setting to turn it off – r-click menu too
- FZ3-11825 Dimension Angle - Custom Text needs to hide the angle value on the dimension angle - like dimension line
- FZ3-11822 Zone 2D - place symbol and rotate during placement. Selection rotates but not vehicle until zoom
- FZ3-11817 Inline Momentum Report- Equations. Need to take into account direction of velocity for -'vs in all cases
- FZ3-11816 Optimization
- FZ3-11801 AS Lite Vehicle Database 2024
- FZ3-11791 Backups not restoring previous drawing if it was unnamed.
- FZ3-11790 Edit Lights - add index and null checks
- FZ3-11784 Fotopoints. halt rendering while fotopoints window is up and processing
- FZ3-11783 PC Merge - Investigate Scans level transform issues. detect and warn
- FZ3-11782 Google Map - Follow Terrain issue with user data terrain
- FZ3-11780 PC Gap Fill- the quick index optimizer doesn't reset when a new point cloud is loaded resulting in gap fill not working
- FZ3-11776 Crush Volume Drone - Can't Delete
- FZ3-11773 Double click Profile on Ribbon creates and error
- FZ3-11770 HDR- going from HDR to Standard and back to HDR causes over saturation of HDR
- FZ3-11768 Skinned Models - Area Select (green) - always picking them in 2D
- FZ3-11766 Critical Speed - remove Full Precision checkbox and check code
- FZ3-11765 RClick menu pops up after a navigation (sometimes) - could not repeat - delete it
- FZ3-11733 Models - Placing from library - Sometimes takes a while to show up in the scene
- FZ3-11732 GCP Manager: row re-population issue if there are less than 3 rows
- FZ3-11731 DateTime picker
- FZ3-11729 Scanner w/ Tripod hidden pickable
- FZ3-11701 Save Selected - Doesn't create an FZProj
- FZ3-11691 FotoPoints: PLY in Input folder error?
- FZ3-11690 PhotoCore should terminate if GCP not found in 3D space
- FZ3-11686 Print - Form - Setup so that in print form it uses only the form layer for scaling
- FZ3-11676 Deploy Faro Assist 2.0 to Production
- FZ3-11669 3D Volume Crush Report
- FZ3-11520 DXF save 2D vehicle - lose too much geometry. Fills and poly's missing
- FZ3-11955 Ortho Lock Tool Tip - Copy 3d to 2D
FARO Zone 3D 2024.5.0523 Release Notes - May 2024
HOT PATCH: This release fixes issues with Zone2Go export. Where an Export fails when annotation folder did not exist.
FARO Zone 3D 2024.5.0507 Release Notes - May 2024
HOT PATCH: This release fixes a bug found in the last release. Imported images such as .jpg or .png are randomly scaling.
FARO Zone 3D 2024.4.0423 Release Notes - April 2024
What's New
FotoPoints
Scaling issue resolved with GCP points.
Best Practice - Setting each GCP point from at least three different images is necessary. Less than that will not guarantee successful GCP scaling. The distance between the GCP points in this example is 20’.
White vehicles handled much better now in FotoPoints. Ghost points from the reflection are non- existent now.
Best Practice – Your phone or camera must have AE/AF lock on.
Geometry mismatches at the edge of large areas fixed.
Fixed - "Process cancelled, no CPE file created" message appeared on larger sets of images (currently 554-image project). The processing then aborts the operation.
Fixed – Dense matching failure.
Fixed – GeoTiff generation error due to image alignment.
Before:
After:
Workflow System and Home Ribbon Updates
The Favorites button (heart) was removed from the Home ribbon. The new Workflow System button was added next to the Import/Export button. The Favorites toolbar button is now in the Workflows toolset. The Favorites button also remains on the Quickbar.
(1) Search Workflows
(2) Favorites
Search Workflows
Favorites Toolbars
Workflow Sheet
(1) Workflow Steps
(2) Print Workflow
(3) Workflow Help Links
(4) Action icons for specific features
Blood Spatter Updates
Edit Droplets Form - Updated UI
1. Fixed Icons
2. Added draw instructions to Ribbon (Guidance Banner)
3. Added Tool Tips to Buttons
4. Changed Edge-Detect to one draw and switches back to edit mode.
5. Spacebar will now do either manual draw or Edge-Detect based on which one was used last.
6. Fixed Null Reference Error Add when drawing droplets.
7. Fixed Mode Lock issue when using scalebar.
Backup System Manager
Restoring Files from the Backup Manager.
You can configure the software to automatically save a project while you are working on it. To enable automatic backups:
- From the FZ3 menu, select
Preferences. You can also select Preferences from the Quick Bar. - Under the Backups section, configure the following:
- Auto Save - Enable this option to automatically save the project at the designated time interval.
- Incremental Save - Enable this option to automatically save the project and keep the designated number of previous saved versions. This allows you to easily revert to previous iterations of a project. This allows you to revert to previous project iterations. For example, if you make several changes that would be difficult to undo, you can simply revert to a version that was saved prior to the changes.
To restore backups that were automatically saved:
- From the FZ3 menu, select Restore Backup. A list of backup folders displays.
- Select the folder that contains the backup of your project.
- Click a file to preview it or click the eye icon next to the file. The project is displayed in the viewer.
- To restore the file to its previous folder, click Restore. You will be prompted for a target folder.
You can also manage your backup files by right clicking a file and selecting options from the context menu, or by selecting Menu. You can delete folders or individual files, open the folder that contains the backup file, etc. To save disk space, you can sort the backups by size and delete backups of larger projects that you no longer need.
Point Cloud Tools and Ribbon Updates
The point cloud ribbon has been re-organized.
- Import “Other” point cloud types was moved under the main point cloud import button.
- Fotopoints were moved next to the Import Point Cloud button.
- The Clipping Box buttons are full size and side-by-side.
- Point Cloud Tools Panel updates.
- Three workflows were added to the top icon menu for creating point cloud ortho images, 2D ortho print image, and a profile line.
- The Point Cloud Positioning tools are now a collapsible menu.
Sun Position Calculator
Position the sun for a specific area and time. The sun position calculator will automatically extract the latitude and longitude from a pre-placed Google map. The GPS data can also be entered manually. Enter the month and time for the correct sun position at that location.
The sun position calculator is on the Sky menu from the Enviro ribbon. Place a Google map before clicking on the “Calculate Azimuth and Elevation” button. If you want to automatically extract the lat/long.
Other Updates
- Printing – Zoom to Mouse Wheel
- Point Cloud – Snap Closest Optimization
- Point Cloud Merge – Supports FZPC files
- CDT – Normalization fixed for GPS data and aligning to Google Map
- DXF – Export fixes for nested groups and line arrow support (polys, curves, and arcs)
- Animation – Misc bug fixes
Bug Fixes
- FZ3-11761 FotoPoints: point cloud orientation is wrong using GCP, GPS
- FZ3-11760 FotoPoints: Relax GPS min distance limitation.
- FZ3-11759 Enable point cloud snap for FotoPoints.
- FZ3-11758 Autosave launching a save as dialog when it is not necessary.
- FZ3-11756 CDT - normalize option to lower elevation points to 0,0, but not flatten.
- FZ3-11749 Global error report - hook it up.
- FZ3-11748 Remove Diagnostics from Help
- FZ3-11742 CDT table: GPS normalization fix
- FZ3-11741 Z2g: Overview map error handling for empty bounding box
- FZ3-11740 Ortho image generation issue
- FZ3-11739 Skydio: PhotoCore GPS option turned off.
- FZ3-11736 Arc - Arrow gap in line - Reduce to make sure there is not a gap in 2D.
- FZ3-11734 Polyline - Context Menu - Remove Point - Not always getting point closest to mouse.
- FZ3-11723 Clipping issues when nested symbols disappear in 2D, they do not show in 3D.
- FZ3-11717 Z2g: not working with merged point cloud.
- FZ3-11690 PhotoCore client should exit if GCP not found in 3D space.
- FZ3-11603 FotoPoints: point cloud alignment issue (GPS?)
- FZ3-11718 Arc - Not rendering if 0 thickness and 0 extrude.
- FZ3-11715 Point Cloud - Create Profile – Elevation issue.
- FZ3-11714 Point Cloud - Tools - Workflow buttons in ribbon.
- FZ3-11713 Animation Path - you cannot swap one body with another on an animation path.
- FZ3-11709 PhotoCore failed to process large image set (554 images)
- FZ3-11708 Animation - Skinned - Cannot Delete
- FZ3-11707 DXF - add arrows to Arcs and Polys
- FZ3-11706 DXF save - support nested groups and line arrows.
- FZ3-11705 Duplicate model after OBJ imported.
- FZ3-11702 Blood Spatter - Switch edge detection to one at a time like a line draw
- FZ3-11696 GeoTiff generation issue
- FZ3-11695 CDT normalization clarification
- FZ3-11693 GPS Reference: no context menu?
- FZ3-11689 GCP Manager: cannot delete the last row.
- FZ3-11688 Merge point clouds issue
- FZ3-11682 Backups - see if .far and .fzproj has the filename attr set to the real file path.
- FZ3-11667 Skid Tool - When deleting last line it does not refresh the table
- FZ3-11664 Zip and Share - if fzproj not configured correctly, message to Save with a new name to fix the project configuration.
- FZ3-11663 Hidden Scanners not pickable, HUD link to Scan Manager
- FZ3-11652 Blood Spatter Analysis - Guidance Banner
- FZ3-11650 Line - Arrow and thickness issue (2D)
- FZ3-11649 Arc - thickness and arrowhead issue
- FZ3-11644 Road 2D arc, render as selected.
- FZ3-11643 Point Cloud - 2D Tiled Image - Switching to 2D causes the cursor to spin continuously.
- FZ3-11641 Ribbon - Point Cloud Tab - Move Icons around.
- FZ3-11583 Point Cloud - Snapping - Need to increase priority of closes point.
- FZ3-11574 CDT with GPS file - issues with Normalize.
- FZ3-11561 Trap for the global crash in Zone 3D and show our own Crash Report form.
- FZ3-11558 PhotoCore image alignment issue
- FZ3-11640 CDT sharing violation when file open in Excel.
- FZ3-11638 Label - Remove padding from geometry and picking if no border or fill.
- FZ3-11637 Bubble Labels - remove Bold/Italics from HUD, change Font combo to down chevron.
- FZ3-11630 PC Merge Issue
- FZ3-11629 FotoPoints PC fading issue
- FZ3-11628 e57 issue
- FZ3-11627 Backups & Zip - review for very large drawings. Remove size restriction.
- FZ3-11626 Models - Damaged model removing parts.
- FZ3-11625 EDR: Metric not available in EDR entry table
- FZ3-11624 Failed to Auto detect .FLS files from SD card.
- FZ3-11623 JPEG vs JPG in Save As vs Camera
- FZ3-11622 File Open (.far) should show all file types .far, .fzproj,.fzproj.zip
- FZ3-11619 Skid Tool - Add option to remove a line that has been added.
- FZ3-11612 Restrict Zip and Share on fzproj's outside their folder.
- FZ3-11596 No default Printer - crashes landscape
- FZ3-11579 Scanner symbols are selectable and can be deleted. They should be 'hidden'.
- FZ3-11563 Roadway Arc - Shoulders / Sidewalks
- FZ3-11547 Print Zoom - Zoom in center on the mouse.
- FZ3-11511 Ribbon - Add new patch available icon to the ribbon.
- FZ3-11510 Layer Report - Add option to flag a layer as background layer to show up on all pages.
- FZ3-11500 Terrain - implementing terrain after first switch to 2D and back.
- FZ3-11591 Two Letter Command - CO - Not working with MassZone.
- FZ3-11548 Time Distance - add Arrow and Leader sizing to Time Distance HUD.
- FZ3-11523 GLTF - Move into the model import function.
- FZ3-11292 Deleted - Roads - Arc - no property for the shoulder
FARO Zone 3D 2024.2.0221 Release Notes - February 2024
What's New
Point Cloud 2D Display
Create a high resolution, top-down image of the point cloud using a clipping box. This image won't appear in the 3D view and is ONLY displayed in the 2D window. This is a fast and easy way to see all your data in both 2D and 3D views. The image can be turned off in the 2D view from the point cloud tools.
Point Cloud Profile Line
Create an automatic profile line in your point cloud from an area defined by a clipping box. Profile lines are useful for creating a profile of terrain, or a roadway. They can help you visualize slope angles. You can place a vehicle side view symbol on the profile line to help establish the driver's line-of-sight. For example, you could establish whether a driver could see over a hill as another vehicle approached from the opposite side.
Point Cloud Enhancements
- Grayscale (Reflection) option for Pano images
Scan Manager and Scanner Tool Panel - Bake Rotation option on the Point Cloud Tools panel. If there are clipping issues with a point cloud after rotating (aligning).
Positioning the Point Cloud - GPS Data from Scans (when available). Turn the scanner display ON in the Point Cloud Tools panel and select a scanner. If available, the GPS data will be displayed.
Scan Manager and Scanner Tool Panel - Copy button added next to the GPS coordinate display.
Performance Updates
- Optimized clipping and rendering. 10x faster when starting a new scene from within Zone.
- Text, paragraphs, and label position and padding have been perfected to align on-screen in the 2D and 3D windows (views) and the print dialog.
- Text center snap added.
- Text border padding option added.
MassZone – Pole Impact System
The MZU Pole option is used for Fixed Barriers that have a small cross section of impact. Due to the higher level of penetration across a smaller cross-section with the colliding vehicle, special considerations must be made.
Setting Up a MassZone Crash Prediction That Includes a Fixed Object
MassZone – Lighting System
Set up light timing in AI-determined Light Categories for your vehicles to time with your prediction run playback. Option for Automatic brake lights. With the option for automatic brake lights based on user input threshold. The system allows for manual control of all the other lights.
Zone-2-Go
Color and Grayscale (Reflection) mode support for pano images (only for SCENE projects with both color and greyscale panos).
Misc
- AXON Connect – Improved connectivity to Evidence.com.
- Copy button added to the Google Map GPS display next to the GPS coordinate.
Bug Fixes
- FZ3-11597 Profile Tool - fixed when curve selected
- FZ3-11587 Ribbon - Close button not working on right side of the button
- FZ3-11576 Symbol Load updates
- FZ3-11554 Fix Bubble Label Text Render 3D
- FZ3-11546 Fix Bubble Label Text Render GDI (Print dialog)
- FZ3-11549 Evidence.com account - set up and tested
- FZ3-11540 Test Label Object Font & Language Change in 2D, 3D, Print
- FZ3-11539 Model - Transparency Slider - Not using value in 2D
- FZ3-11538 Symbol - Transparency - Not working in GDI Print
- FZ3-11534 PolyCurve Rendering Improvements
- FZ3-11533 Optimize 2D Animation Path Rendering
- FZ3-11532 Label GDI, 2D, 3D Text Render Improvements
- FZ3-11519 Report Center - Add option to open reports - Skid Analysis / Profile
- FZ3-11518 Crush Calculator - When reversed the grips are wrong
- FZ3-11517 Favorites - Place symbol does not go to the History
- FZ3-11513 DXF save symbols bug fix
- FZ3-11509 Videogrammetry: Custom device deletion issue
- FZ3-11503 Photopoints add/remove custom device tweaks
- FZ3-11507 Drag drop lsproj, e57, las, fzpc
- FZ3-11506 Google Maps blue box - when nothing in Save location list
- FZ3-11505 HDR PANO Recording Nighttime and lights
- FZ3-11486 Blood Spatter - Allow exporting a CSV from blood spatter
- FZ3-11480 Test - CDT - Points and text size wrong in print form
- FZ3-11477 Pano progress form - On top and other issues
- FZ3-11470 Translations 2024 - integration + German update
- FZ3-11466 Cleanup Videogrammetry/Photogrammetry best practices links
- FZ3-11390 ca 555 report forms - Revisit placements
- FZ3-11137 Pano recording - exception error when recording
FARO Zone 3D 2024.1.0117 Release Notes - January 2024
Bug Fixes
- FZ3-11489 GeoTIFF generation optimization
- FZ3-11485 FotoPoints registration report issue
- FZ3-11451 FotoPoints - Remove bad messages
- FZ3-11433 FotoPoints project log file
- FZ3-11411 Videogrammetry not showing in favorites (check Photogrammetry too)
- FZ3-11465 Add a spinner at the final stage of photogrammetry
- FZ3-11454 Photogrammetry: re-center point cloud after CPE import
- FZ3-11434 Photogrammetry: scalable point cloud workflow
- FZ3-11484 Mouse Wheel - Ortho Graphic 3D - Not using the reverse mouse wheel
- FZ3-11468 Models / Animation Path - Light Form - Refresh issue with selected number edit boxes
- FZ3-11464 Print to Arch C with FARO Zone Driver
- FZ3-11418 Printing - If there is a print form always use print form rather than having both normal print and print form options
- FZ3-11460 Report Center - MZU Report
- FZ3-11457 Report Center - Animation - Time Distance Report
- FZ3-11455 Report Center - Layer Report Issue with print form closing automatically
- FZ3-11438 Layer Mgr report needs tooltip
- FZ3-11414 Report Center - Add Zone 2 Go
- FZ3-11444 Scalebar - Variable Small Increments 2D
- FZ3-11442 Scalebar - Option to remove from lighting
- FZ3-11392 Scalebar - Not automatically changing units in 2D
- FZ3-11441 Vehicle Spec, record count issue
- FZ3-11450 CDT import dxf point
- FZ3-11425 Skinned Model - Not saving attachment
- FZ3-11424 Mag Window - Airplane mode not working - doesn't display full drawing but panning inside works - works in 3D, not 2D
- FZ3-11423 Billboard - Create a preference for keeping the object when billboarding
- FZ3-11415 EDR Hud images grainy
- FZ3-11409 Blood Spatter - Mode sometimes gets locked if you switch from auto to edit mode and delete a droplet
FARO Zone 3D 2024.0.1206 Release Notes - December 2023
What's New
FotoPoints – Ortho Image (GeoTiff)
GeoTiff image files are geo-referenced and will drop on top of a Google Satellite map in Zone at the correct scale, location, and orientation.
Using FotoPoints to Create a GeoTIFF file (click here)
FotoPoints – Videogrammetry
Use video footage from your phone, drone, or other camera to generate a point cloud with FotoPoints in Zone.
Creating a Point Cloud from a Video (click here)
Videogrammetry – Best Practices
Follow the guidelines in this document to help you get the best results from your video, photo, and drone data.
FotoPoints Guidelines and Tips (click here)
MassZone Crash Prediction System
Quickly and easily create "what if" scenarios of various crash types. Add your existing animation to the MassZone system and compare your results with MassZone's prediction animation.
About FARO Zone 3D MassZone (click here)
Billboard Annotation Tool
Select any object, such as a text, symbol, or 3D model, and elevate it in the drawing so that it is always visible. This allows you to annotate the important parts of your drawing with any object type.
Annotation Billboard Tool (click here)
Rear View Mirrors
Left, Rearview (Center), and Right-side vehicle mirrors can be placed, positioned, and adjusted to simulate real mirrors in Zone animations and crash predictions.
Setting Up Rear View Mirror View in MassZone (click here)
Report Center (Experimental Ribbon)
One click generates a list of all reports available in your current project.
Reports Center (click here)
GLTF Import (Experimental Ribbon)
Import .gltf files directly into Zone. These are mesh models that can be scaled and oriented in Zone. Skydio uses drone data to create these models.
Importing GLTF Files (click here)
Import and Convert Legacy Point Cloud Types directly to .lsproj Types
Import any e57, las, pts point cloud into Zone without any data loss.
Import Other Point Clouds (click here)
Vehicle Specs – Apply to 2D/3D Models
When you're working with vehicle models, you can easily apply vehicle characteristics from the Vehicle Specs Database to ensure that the wheelbase, tires, etc. are as accurate as possible for the model.
Applying Specs from the Vehicle Specs Database to a Model (click here)
Favorites Tool – Workflow Toolbar System
The Favorites tool allows you to add (and remove) features, symbols, models, or signs to a scalable toolbox. Preset and saved custom toolbars can be loaded on-the-fly for various project types. Any custom toolbar can be modified on-the-fly, and you can easily create new ones.
Favorites (click here)
Match and Clone
Use the Match Object tool to replicate the properties of a selected object so that you can reuse the object and its properties elsewhere in your drawing. Double-click an object to Clone its properties and draw or place the object if it’s a symbol or model.
Match and Clone Objects (click here)
Copy/Paste Multiple Images
From Windows File Explorer, you can select and copy (Ctrl+C) multiple images, and then paste (Ctrl+V) them in your drawing.
Copy/Paste Multiple Images (click here)
A.I. Vehicle Detection and Image Clean-Up
The satellite image clean-up tool just got a whole lot easier and more fun! This tool uses A.I. functionality to automatically detect and select vehicles in the satellite image. The clean-up tools have also been updated and simplified.
A.I. Vehicle Detect and Image Cleanup (click here)
DXF/DWG 2018 – Import/Export Latest DWG Format
The AutoCAD™ drawing format is used worldwide to share CAD diagrams. 2018 is the latest iteration of this format.
FARO License Manager 2.0
The new License Manager replaces the previous browser-based version to allow you to easily manage your licenses.
FARO License Manager (click here)
Bug Fixes
- FZ3-11355 Cabinets - Slowdown 2D render
- FZ3-11353 Ribbon Icons - Skinned Import - Make sure icons are the same.
- FZ3-11348 Ellipse Select - Fix issues with corners.
- FZ3-11346 Ground UI - Fix up.
- FZ3-11336 Trajectory - Protractors Print - Not scaling.
- FZ3-11191 Trajectory - Not Printing Protractors
- FZ3-11334 Crush - C1 Grip not coming back after zero.
- FZ3-11322 Crush Tool - Not allowing changing all three colors.
- FZ3-11283 Crush - Grips - If Zero length don't allow selecting on the C1 and C6 points.
- FZ3-11332 Select Area - Tool Tip changing to wrong one during move.
- FZ3-11293 Selection - Crossing - Make it dashed.
- FZ3-11290 Multi select - dash selection window for crossing.
- FZ3-11319 Multi-Select - On Intersection - Won't allow selecting multiple models.
- FZ3-11329 Signs - reverse localize Chinese.
- FZ3-11324 Signs - broken when not English.
- FZ3-11267 CZD import issue multi-line text not positioned correctly.
- FZ3-11301 EDR: Benjamin's crash pulse issue
- FZ3-11291 Animation Camera - UI - Change preview icon to one from witness view
- FZ3-11276 Animation Path - Add Reverse angle button.
- FZ3-11288 Roof Tool UI - Fix
- FZ3-11286 Total View - Ortho Camera - Top-Down Positions don't create animation camera path.
- FZ3-11281 UI - Recording - Change the green button to Red.
- FZ3-11275 Models / Animation Path - Lights Issue.
- FZ3-11266 Roadway Arc - Lines set to hidden are still shown.
- FZ3-11219 Symbol Parts - doesn't allow you to use the color dropper to match a color property
Experimental
Welcome to the FARO Zone Experimental feature review system!
What is it? – This unique system provides an opportunity for users to review new features that are still under development and offer feedback directly to the FARO software development team. If you choose to participate, you will be able to try out new features before they are officially released to all users.
Who can use it? – The experimental features are available to any user that accepts the terms of usage agreement.
How to use? – Open Preferences and select the “General” option. Click on the “Enable FARO Experimental Features” option. If you haven’t already done this, you will be prompted to accept the agreement and enable features if you click on a feature in the Experimental ribbon.
- Review the Experimental Release Notes. Using the features that appear in the “Experimental” section of the ribbon menu.
- Use the “Snippet” tool to screen capture program issues and attach to a support email.
- Submit your comments via email by clicking on the Support email button in the Experimental ribbon.
Report Center
GLTF Import
FARO Zone 3D 2023.9.0906 Release Notes - September 2023
Updates
Performance and Optimization and Stability Work,
Bug Fixes
- FZ3-11237 Billboard - UI - Add explode option.
- FZ3-11227 Billboard context menu is wrong.
- FZ3-11185 Billboard - Witness Tool - object isn't orientated correctly (pitch / yaw) on initial creation.
- FZ3-11234 Navigation - Scene Navigation Mode - Doesn't take reverse mouse wheel direction into account.
- FZ3-11231 Animation Path - If KEP visible turned off turn off lights at that KEP
- FZ3-11239 Animation Path - Articulation - Add KEP issue.
- FZ3-11229 EDR: Clockwise steering issue
- FZ3-11223 Lose keyboard after eyedropper used.
- FZ3-11193 Cabinets - GPU Memory Leak - U Shape
- FZ3-11192 FORMS, add, green margins, "X" for text, default OFF.
- FZ3-11189 New Legacy PC Imports UI and Workflow
- FZ3-11153 Curve - Offset - Custom Control Grips offset issue.
- FZ3-11047 3D Warehouse - get 2022 SDK.
- FZ3-10146 Application Crashed When Changing Color/Shine of Tire Tracks for Animation Path That Wasn't Visible
- FZ3-9357 FZ Surface UI missing Grass properties
FARO Zone 3D 2023.8.0817 Release Notes - August 2023
Updates
FotoPoints: GCP (Ground Control Points) Updates
Click the GCP marker in the GCP dropdown. The image that contains the marker opens and zooms in to the marker. You can select the menu item from the hamburger menu button to remove the GCPs.
Click the GCP name to replace the GCP marker. The image list scrolls so that the image that contains the marker remains visible.
Zone 2go Updates
New and improved Zone2Go dialog box:
From the Zone 2go ribbon, click
Annotation to add an annotation.
Click
File Reference to add a file reference. You only need to set one point for the location.
Click
Pano Image to add a 360 Pano image at this location.
Click
Witness to add a witness view.
Click
on the right-hand side to export Zone 2go project.
Match and Clone
For example, if you are creating a road drawing and you make a dashed road line that you'll need to reuse in other parts of the drawing, you can use the Match Object tool to replicate the properties of the dashed line.
You can use the Match Object tool for many objects in your drawing, including lines, labels, dimension arrows, shapes, etc. You also use it to duplicate symbols and models.
To use the Match Object command:
The Match tool appears in the HUD after you use a tool, or after you select an object.
- Select the object to modify, and then click the Match tool from the HUD. The F2 key also launches the Match tool.
- Click the object from which you want to duplicate properties.
- The selected object inherits the properties of the second object that you selected.
Clone (Double-click)
Double-click an object to clone its properties and draw or place the object if it’s a symbol or model.
Clone (Spacebar)
Select an object and then hit the Spacebar. This command clones the properties of the selected object and starts drawing the entity.
Why use the Spacebar instead of double-clicking?
- Double-click text to open the text edit dialog. Click the Spacebar to start drawing text that matches the selected text.
- In detailed drawings, it can be difficult to double-click an object. It’s easier to zoom in on the object, select it, and then hit the Spacebar to draw the object that matches the properties of the selection.
Bug Fixes
- FZ3-11182 Zone2go Overview map boundary issue
- FZ3-11179 Zone2go output folder validation
- FZ3-11181 Fire_Forms_Fixes
- FZ3-11175 Label Draw - Select Textbox after draw
- FZ3-11159 Start page "Register" label has the g cut off.
- FZ3-11154 Bubble Label - dblclk not picking up text.
- FZ3-11127 Arc - UI - Tooltips on pbr material box
- FZ3-10889 Symbols - Add option for single paint color
- FZ3-11007 Symbols - Create - Doesn't automatically generate an icon
- FZ3-11167 PC- Import PTS direct to LSPRoj, bypassing 150M point limit and requirement for FZPC
- FZ3-11081 Time Slider - Add Option to increase size
- FZ3-11068 Bullet Trajectory - Protractor color not working - change from HUD
- FZ3-10913 PBR Printing Surface... print color different
FARO Zone 3D 2023.8.0801 Release Notes - August 2023
Updates
Zone 2go Updates
Click
Click
Click
Click
Match and Clone
Clone (Spacebar)
Bug Fixes
- FZ3-11126 Add Billboard Option to context menu
- FZ3-11118 Billboard - Signs - Add to context menu
- FZ3-11117 PC Pano with fly through camera issues
- FZ3-11111 Property line HUD missing Match icon
- FZ3-11109 Match if miss object pick stay in command
- FZ3-11107 HUDs show Match icon after command complete
- FZ3-11106 GCP Manager UI tweaks
- FZ3-11103 Bubble Label GDI - re-fix
- FZ3-11102 Favorites - remove Signs button - add to favorites go to 3D
- FZ3-11095 Arc - PBR - Not saving / Loading
- FZ3-11094 GPS pin - Z-fighting after move and snap 3D
- FZ3-11084 Create Eyes-only Experimental option
- FZ3-11082 FotoPoints: Orthophoto process error message
- FZ3-11077 Unitframes option for animation
- FZ3-11074 Add a Momentum layer
- FZ3-11073 Roadway - Single Line - Can't change sidewalk color
- FZ3-11071 Ribbon - Line Break Tool not working properly
- FZ3-11059 Start page - Pin, Move to front, Favorites - same UI as Favorites tile (Paul)
- FZ3-11058 Transfer Properties - Match object to transfer properties. Add match icon to HUDs
- FZ3-11057 Match Circles not matching all properties (Fill, thickness)
- FZ3-11056 Double click single bubble label picks the 1/n method
- FZ3-11052 Billboard - Evidence Markers - Setup Default Orientation, add context menu
- FZ3-11051 Billboard - UI - Angle Increments - Major 45 degrees
- FZ3-11050 Billboard - Fireman - Not visible when billboarded
- FZ3-11049 Billboard - Image - setup default orientation for images
- FZ3-11048 Billboard - Skinned Model - Add special default to billboard
- FZ3-11046 Intersection - Arc Tangent - Creating black lines
- FZ3-11021 Snapshot Tool - Needs option to fill background
- FZ3-11011 GPS Pin - Add Facing Option
- FZ3-11000 GCP Marker panel: select and zoom in
- FZ3-10998 GCP marker auto scale
- FZ3-10891 Z2g dialog facelift
FARO Zone 3D 2023.7.0724 Release Notes - July 2023
Updates
Zone 2go Updates
Click
Click
Click
Click
Match and Clone
Clone (Spacebar)
Bug Fixes
FARO Zone 3D 2023.6.0623 Release Notes - June 2023
Updates
- Break command fix
- Orthophoto process messaging improvement
- GPS GDI fix
FARO Zone 3D 2023.6.0620 Release Notes - June 2023
Updates
FotoPoints: Importing GCP data from the text file
Import the GCP data from a text file to quickly populate the fields in the GCP Manager. To import GCP data:
- From the FotoPoints window, click GCP.
- Click GCP Manager.
- Click Import GCP. The Coordinate Data Table displays.
- From the column on the right, select the appropriate format for the GCP file.
- The proper format for the following example is Pt#, North, East, Elev, Desc
- Click Open, and then browse to, and open the GCP configuration text file.
- Check the boxes for the GCPs that you want to include.
- Click Finish. The GCP Manager is populated with the GCP points from the text file.
- Click OK.
- Select the images that contain the GCP markers and select the GCP entries. For more information on selecting GCP images, see the FotoPoints section in the user manual.
FotoPoints: Creating an Ortho Photo
You can create an ortho photo from the FotoPoints point cloud. Use the photo in reports, fly-thrus, etc. To create an ortho photo:
- From the FotoPoints window, click Ortho Photo.
- Select a level for Outlier Detection to remove surrounding noise from the photo.
- The output folder is the folder that you selected for FotoPoints.
- Note: The output folder must be empty before you generate the ortho photo. If you have created an ortho photo in that folder previously, you must delete the contents of the folder.
- Click Generate. The FotoPoints point cloud regenerates, and the ortho photo is created from that point cloud.
- The software generates a .png file. You are prompted to import the file after the software creates the ortho image. Depending on the size of the file, you may be prompted to import the file as a tiled image. This is recommended for larger images.
Match Object
Use the Match Object tool to replicate the properties of a selected object so that you can reuse the object and its properties elsewhere in your drawing. For example, if you are creating a road drawing and you make a dashed road line that you'll need to reuse in other parts of the drawing, you can use the Match Object tool to replicate the properties of the dashed line.
- Select an object in the drawing that you'd like to re-use.
- From the quickbar, or from the Draw/Edit ribbon, click Match Object
. - Draw or edit the object.
Note: To re-use objects in multiple drawings, use the Favorites tool.
Billboard
Select any object, such as a text box, symbol, or 3D model, and elevate it in the drawing so that it remains visible. This allows you to annotate the important parts of your drawing.
Billboards are also useful for identifying important subject areas in large images with terrain.
To designate an object as a billboard:
- Select an object.
- Right click the object and select the Billboard command (for symbols and models), or select the
command from the Text dropdown.
- Use the grip to adjust the height.
- Click Edit Object to change the settings for the object selected as the billboard.
- Adjust settings in the Billboard tool panel (see below).
- Add other billboards that you think are necessary to call out in the drawing.
Billboard Tool Panel
| Layer | Add the billboard to a new or existing layer. |
| Arrow and Pole color | Use the color picker tool to select the color for the arrow and the pole. |
| Reset | Reset the tool to its default settings. |
| X, Y, Z Values | Displays X, Y, Z values, which you can change by entering values, or by using the dial arrows. |
| Yaw, Pitch, Roll | Adjust: Yaw: ![]() Pitch: ![]() Roll: ![]() |
| Scale | Adjust the size of the billboard. This is useful for sizing the billboard so that it displays clearly, depending on the size of your point cloud, map, or other aspects of the drawing. |
| Show Post | Display or hide the post for the billboard. You can adjust the size and offset of the post. |
| Post Vertical | Enable this option to keep the post vertical under the billboard. Disable this option to offset the base of the post with the grip.![]() |
| Show Arrow | Display an arrow at the base of the post.![]() |
| Post Length | Adjust the length of the post.![]() |
Center Scene on Point Tool
The Center Scene on Point tool allows you to quickly re-origin your diagram to the center (0,0) of the drawing grid. For example, you could have an area of the drawing with locked layers, and if you move an object in one of the layers, the objects in the other layers are not moved along with the object that you selected.
To re-origin your drawing:
- From the Draw/Edit ribbon, click Center Scene on Point.
- Find the point that you want to designate as the center of the drawing.
- Click the point.
- The drawing (including the hidden layers) re-orients at that point.
- When you display all of the layers from the Layer Manager, you will see that everything in the drawing is repositioned.
Note: This command does not center point clouds.
TotalView Total Time Playthrough Option
The new Total Time option allows you to specify the time duration of your TotalView animation playback. After you add the images for your TotalView animation, you can set the speed with the following options:
- Walk-Thru - View the fly-through at 3 mph.
- Fly-Thru - View the fly-through at 30 mph.
- Custom - Customize the speed by selecting the feet per second (fps).
- Total Time - Specify the number of seconds for the duration of the fly-through. This option provides an easy way to adjust the playing length of the fly-through. You can adjust the timing for individual snapshots in the KEP Manager.
Bug Fixes
- FZ3-11042 FotoPoints: Orthophoto auto scale issue
- FZ3-11001 FotoPoints: Tool Strip control selection highlight
- FZ3-10969 FotoPoints: Scalebar save/load
- FZ3-10906 FotoPoints: GCP workflow refinement
- FZ3-10870 FotoPoints: GCP auto import
- FZ3-10848 FotoPoints: new SceneAPI issues
- FZ3-10841 FotoPoints: GCP data save/load
- FZ3-10810 FotoPoints: GCP Point cloud not centered?
- FZ3-10807 FotoPoints: GCP Point cloud quality issue
- FZ3-10698 FotoPoints: GCP UI review
- FZ3-11041 Orthophoto page: remove Quality slider
- FZ3-10905 PhotoCore Orthophoto backend support
- FZ3-10838 Ortho Image- Scene - Should work with a disabled clipping box
- FZ3-10837 Ortho Image - Legacy - Should work with a disabled clipping box
- FZ3-11038 Snaps - Snapping up in the air - as if it's snapping to the camera
- FZ3-11037 Animation Camera - Roll Mode not in UI
- FZ3-11036 Animation Camera - Change Ortho Mode to top down only
- FZ3-11034 Increase allowed lights to 128 for EXPERT
- FZ3-11030 Explode group does not maintain scaling of linetyped objects
- FZ3-11029 Polycurve fences drawn as polylines - all but horizontal post don't work
- FZ3-11028 Match Arcs not remembering linetypes
- FZ3-11025 Favorites - 2D symbols don't place in Debug
- FZ3-11024 Group not showing HUD toolbar
- FZ3-11023 Remove 'would you like to load the point cloud' message
- FZ3-11022 Translation - find 'dead' strings
- FZ3-11020 Ribbon - Align Icon - Wrong Icon
- FZ3-11019 Directional Line - Double convert
- FZ3-11018 GCP import refinements
- FZ3-10911 GCP Tab / GCP Manager review
- FZ3-11017 Billboard - 3D - Allow Selecting the post
- FZ3-11006 Billboard - On Terrain - Start post at position of the model not zero
- FZ3-10984 Billboard - Edits
- FZ3-10981 Billboard - 2D / GDI
- FZ3-10980 Billboard - Save / Load
- FZ3-10979 Billboard - Add option for pole without arrow
- FZ3-10888 Symbol - Billboard Option
- FZ3-11015 Unable to Reproduce - Chamfer / Fillet - throwing error on undo and cancel
- FZ3-11013 Unable to Reproduce - Fillet - Cancel - Crashes in 2D Mode
- FZ3-11009 Google Maps - UI - Remove Facing Camera
- FZ3-11008 RTMirrors- Point Cloud
- FZ3-11005 FBX Importing UI/Workflow refinements
- FZ3-10999 Match Command - bug fixes
- FZ3-10989 Match command - F2, Rclick, selected and non-selected objects
- FZ3-11045 Match - Single line scuff launches polyline tool - same for yaw mark and critical scuff
- FZ3-10995 Update newsfeed 'zip' download OR 'streaming'
- FZ3-10992 colorpicker - paste hex color doesn't update
- FZ3-10991 Articulation - Guide Lines Print weirdness
- FZ3-10990 Articulation - Show Guides - Add to tiretracks UI as well
- FZ3-10983 Line - Pick 3D - Thick / Dashed Annoying
- FZ3-10982 Line - Arrow - Not using PBR color
- FZ3-10976 Open File from Start Page then leave Zone, come back and Open Dialog is behind
- FZ3-10975 Remove Dim Label from Dim options in Quick Ribbon - 2D
- FZ3-10974 Area - remove auto size and move Font Size only to main options - 3D/2D
- FZ3-10973 Favorites in HUDs - remove all Heart icons
- FZ3-10972 Linear Momentum Save/Load bug
- FZ3-10964 Support Ctrl+C, Ctrl+V in HUD edit boxes
- FZ3-10963 BloodGlobalManager disposal issue?
- FZ3-10961 ACADSharp - - missing objects
- FZ3-10960 DWG issue - creates a zero pt continuous line
- FZ3-10953 AS Lite Vehicle Database / CARSP
- FZ3-10950 Articulation - UI - Missing option to turn off yellow paths
- FZ3-10949 Fly Through - When creating the camera turn the Animation Camera layer back on if hidden.
- FZ3-10948 Rename "Print Snapshot" to "Create Snapshot" - FZ2D
- FZ3-10947 Quick Ribbon Polycurve - arrows draw with Polyline
- FZ3-10946 Flex lines need custom curve option - poly curves
- FZ3-10945 Arc - arrow linetype from Quick ribbon not working
- FZ3-10944 Intersection HUD - Median color tiny
- FZ3-10942 PC - Root Transformation. Better Error Message. Disallow load
- FZ3-10939 Total View - Add option for Setting the total time
- FZ3-10937 DWG 2018 - error message direct user to TrueView (link)
- FZ3-10936 Bubble Label - 3D - long text formatting
- FZ3-10904 Context Menu updates
- FZ3-10903 Integrate Scene API into Intouch Branch
- FZ3-10902 Rectangle Draw - 3pnt - Lag During draw
- FZ3-10901 Animation Camera - Add toggle to allow for rolling the camera
- FZ3-10900 Road Line - Save / Load - Side walk save
- FZ3-10896 Articulation - Lights - Not setup for use
- FZ3-10895 Articulation - Lights - Lights Desyncing
- FZ3-10890 Drawing - Re-Origin Tool
- FZ3-10886 Bubble Label updates
- FZ3-10885 Virtual Survey - 2D HUD doesn't match 3D HUD
- FZ3-10882 Circle - 2 Point Draw - Direct Distance
- FZ3-10872 Symbols - Dropdown - Image don't reload without a mouse move despite download
- FZ3-10871 Text - Printing offset issue
- FZ3-10862 FZ2 - Import Export - Update to 3D version
- FZ3-10861 Flex Tool - Show area on left
- FZ3-10865 Rectangle - 3pnt Draw - Add direct distance support
- FZ3-10863 Multi-Select - Select items individually - Not updating the elevation value properly
- FZ3-10855 Momentum Save/Load with Custom Model attached
- FZ3-10853 Tiled Images doubling images on Save
- FZ3-10849 Start Page - Using Admin Settings displayed
- FZ3-10835 Symbol - placing multiple - doesn't continue using the origin point
- FZ3-10834 Fence Horizontal - PBR error if drawn (not good neighbor)
- FZ3-10842 Agency Builds (NYPD)
- FZ3-10826 Axis / Ground Plane - Clean up and add transparency for grid
- FZ3-10824 2D_Symbols_Icons
- FZ3-10823 Z2g: Option to enable measurement function in Scene 2go viewer
- FZ3-10820 Symbol Libraries - Clean up
- FZ3-10818 Join - Ability to connect lines / polylines / curves into one object
- FZ3-10814 Axon progress bar - Approve James' PR
- FZ3-10812 Convert Icons - Wrong icon for this fence
- FZ3-10808 Favorites - Workflows
- FZ3-10804 Symbols - Add an option to change the title bar of the catagories
- FZ3-10803 MZU Getting MZU Demo Ready for Rus in WREX
- FZ3-10802 Articulation - Animation Path UI - Cleanup
- FZ3-10794 Dimension Angle - Outside Arrows - not working in 3D
- FZ3-10783 Intersection - Turning Lane - Not saving length property
- FZ3-10778 Drag multiple images from File Explorer - only places 1
- FZ3-10764 EDR: Crash pulse data issue
- FZ3-10760 Hover text on texture button shows key name - should display Name
- FZ3-10758 Evidence Marker Rotation controls
- FZ3-10044 Reality Import - Missing Animation Path
- FZ3-9981 FZ Bubble Picture needs facing camera option
- FZ3-9592 Line Types - add Good Neighbor Fence
FARO Zone 3D 2023.4.0427 Patch - April 2023
Updates
- Legacy license import/export menu fix
FARO Zone 3D 2023.4.0411 Patch - April 2023
Updates
- This patch addresses a bug in saving Tiled Images.
FARO Zone 3D 2023.4.0404 Release Notes - April 2023
Updates
Favorites Tool
To open the Favorites tool click the “heart” icon on the Quickbar or from the Home ribbon.
Favorites Layout:
- Select and/or edit Custom Toolbars and change icon sizes.
- 3D Models
- 2D Symbols
- Signs
- Commands
- History
Populating Favorites - Commands
Right-click on any program command and click Add To Favorites.
NOTE – Any items or commands that add to Favorites are automatically stored in the correct sections. This includes: Commands, Signs, and 2D and 3D symbols/models.
The command appears in the Favorites menu under Commands.
Add multiple commands that help you with your specific workflow.
Populating Favorites – 2D Symbols
Right-click any 2D symbol and select Add To Favorites to add the 2D symbol to the 2D section.
Populating Favorites – Signs
Right-click a sign and select Add to Favorites to add the sign to the Signs section.
Populating Favorites – 3D Symbols
Right-click a 3D model and select Add to Favorites to add the symbol to the 3D section.
Removing Items from Favorites
Right-click a favorite and select Remove to delete it from Favorites.
Organizing Favorites
Right-click an item in Favorites and select Pin to move the item to the front/top left or select Move to Top. Pinned items supersede items that are moved to the top. You can also remove items from the dropdown menu.
Toolbar Options Menu
From the Toolbar Options menu, you can:
- Choose custom toolbars
- Create new toolbars
- Edit toolbars
- Choose between large and small icons for visibility or space economy.
Creating a new toolbar
When you create a new toolbar, you are prompted to name it. When the toolbar is open, any symbols are commands that you add to Favorites are added to that toolbar.
Editing a toolbar
Click Edit Toolbars to display options for toolbars. You do the following:
New – Create a new toolbar
Duplicate – Duplicate the selected toolbar. This is useful when you want to copy many of the options in an existing toolbar, add/remove/customize the options, and then save the toolbar as a different name.
Rename – Rename the selected toolbar.
Delete – Delete the selected toolbar.
Folder – Open the folder that contains the toolbar .XML files. You can send the toolbars to other FARO Zone users to load (import).
From Windows File Explorer, you can select and copy (Ctrl+C) multiple images, and them paste (Ctrl+V) them in your drawing.
Smart Roads – Lane Add/Remove Grips
You can add or remove road lanes by selecting the outer lane and using the grip. To add lanes, drag the grip toward the road's edge. Drag the grip toward the median to remove lanes. You can use this feature in 3D and 2D modes.
Easily find Zone 2D symbols in the Symbol Library
If you’re working in 2D, and you need symbols, you can easily find them in the Symbol Library.
All Zone 2D Symbols are included in FARO Zone 3D’s Symbol Library
Find all Zone 2D symbols in the symbol library.
Bug Fixes
- FZ3-10584 Momentum Vehicle Details needs to link into Vehicle Specs and fill itself out
- FZ3-10581 Change Layer Manager "Google Map" > "Satellite Image"
- FZ3-10478 FZ Custom Signs. Saving/Loading is using an absolute path instead of reference.
- FZ3-10787 Symbols - Dropdown Libraries - Edits
- FZ3-10786 FZ2 - release version exceptions on this drawing - investigate chair symbols
- FZ3-10757 Symbols - UI - Symbol Parts - Hide Part not saving / loading
- FZ3-10662 Symbols All - installer
- FZ3-10752 Articulation - Animation Path - Missing Start Hidden Option
- FZ3-10777 Shadows- quality/clipping issue
- FZ3-10700 Agency Builds FZ2D
- FZ3-10755 Translations - String ID issue
- FZ3-10754 2D Assets for 3D - investigation
- FZ3-10753 PDF transparent images not working - related to PDF white dot issue
- FZ3-10747 CDT and probably HUD edit fields -6'2" -> 5'10" - investigate (Works)
- FZ3-10746 CDT - Tab between fields
- FZ3-10744 Printing - Texture transparency not working
- FZ3-10761 EDR: Yaw Rate update issue
- FZ3-10782 EDR: Options not restored properly
- FZ3-10721 Paste multiple images
- FZ3-10711 Ctrl+V to paste images
- FZ3-10722 Paste - unify all Paste commands 3D/2D
- FZ3-10717 PDF white dots on image.
- FZ3-10699 Grid 2D - Axis Isn't resized with grid size change
- FZ3-10106 Airplane mode (no internet) - null reference exception in LibrarySection.cs on startup
- FZ3-9857 Animation Camera - Add option for Ortho Mode
- FZ3-9726 FZ2 - remove Import tab from Ribbon - other UI
- FZ3-10723 FZPC Save broken
- FZ3-10709 Ribbon - Intersection Dropdown - Remove new 1 lane templates
- FZ3-10706 Test SCENEAPI Preview for compatibility issues
- FZ3-10704 Object Detection - Research / Setup / Azure
- FZ3-10695 AI object detection knowledge transfer
- FZ3-10694 Durham - Dropdown / preferences
- FZ3-10676 FZProj Files - may be embedding models take a look
- FZ3-10670 Intersection - Add grip for changing the lane count
- FZ3-10669 Road - Add grips for changing the lane number
- FZ3-10640 Skinned Model - Lock Motion to path - Walking drunk has hair moving independently
- FZ3-10611 Zone 3D - Remove terrain - save / load comes back
- FZ3-10586 Momentum - needs option to choose a "3D Model" from the Scene to use
- FZ3-10585 Model UI - needs an option to open Vehicle Specs
- FZ3-10677 Cleanup Tool - controls missing with 4K 225%
- FZ3-10674 PDF thick lines - Dave Bean - investigate
- FZ3-10671 DLC Content FilesAll.zip - missing thumbs
- FZ3-10666 Round Post Fence - Using it for a railing on the stairs causes problems with posts
- FZ3-10664 SVG buttons draw with black background in Start Screen and Google Maps
- FZ3-10663 Stairs Line - Rework
- FZ3-10659 Durham - Enterprise + Templates
- FZ3-10657 TotalStationDownloader install
- FZ3-10651 Pointcloud Ortho Top down from clipbox-rotation issues, exploration
- FZ3-10719 Point Cloud Model - Snapping
- FZ3-10645 Smart Road SVG icons new... Special Amazon Van model for Paul-started...
- FZ3-10643 Model updates...
- FZ3-10641 Updated icons
- FZ3-10638 Roadways - Add 1 lane either way for each type (include arc, line, intersection)
- FZ3-10637 Camera Mode - Close in indicator doesn't highlight
- FZ3-10627 FotoPoints png/tiff/bmp/gif support
- FZ3-10376 FotoPoints XYZ point cloud output
- FZ3-10656 FotoPoints: Hook up PhotoCore GCP support
- FZ3-10655 FotoPoints: GCP UI
- FZ3-10620 AI object detection intro
- FZ3-10588 Axon - Clean up temp files after upload/download
- FZ3-10633 Axon - Download Modal gives false negative
- FZ3-10665 Axon - upload Zone2Go project
- FZ3-10462 Axon - Upload/Download performance improvements
- FZ3-10678 Axon - refresh quick bar when axon permission changes state
- FZ3-10702 Axon - Chunking performance improvements
- FZ3-10675 Remove double separator in quick bar when Axon off
- FZ3-10051 Zone 2D grid snap on launch
- FZ3-10798 Favorites - Models not triggering DLC download if added from the ribbon
- FZ3-10797 Favorites - laundry list
- FZ3-10795 Svg to Png converter - used by Favorites Commands
- FZ3-10792 Favorites - add Commands to Zone 2D
- FZ3-10791 Favorites - save favorites.xml when frmFavorites not open
- FZ3-10788 Favorites - Migrate to Zone 2D
- FZ3-10781 Favorites - Search symbols go to Recent tab
- FZ3-10780 Favorites - Pinned/Unpinned tiles, Remove all but pinned r-click menu command
- FZ3-10779 Favorites - Add 3D Warehouse to Recent tab
- FZ3-10784 Favorites - move to favorites.xml
- FZ3-10769 Favorites Pinned, 3D warehouse
- FZ3-10518 SOC2-014 2023 REVISION
- FZ3-10740 SOC2 - 2023 Reset - iteration
- FZ3-10768 SOC2 Risk Assessment 2023
- FZ3-10616 mzu UI/Workflow Refinements
- FZ3-10763 mzu on going collision model refinements
- FZ3-10762 mzu tire-road model on going refinements
- FZ3-10738 mzu p2- UI refinements
- FZ3-10737 mzu on going refinements to tire-road model
- FZ3-10736 mzu on going refinements to collision model
- FZ3-10735 mzu active driver, reverse mode
- FZ3-10692 MZU Open World UI pt2
- FZ3-10691 mzu Active Driver mode UI
- FZ3-10614 mzu p1, on going refinements to tire-surface model
- FZ3-10613 mzu p1. on going refinements to collision-damage prediction
- FZ3-10693 mzu Active Driver prototype
- FZ3-10654 MZU - Open World Scenario save/load
- FZ3-10653 mzu p2. Open World Prediction UI setup, p1
FARO Zone 3D 2023.1 Release Notes - January 2023
Updates
- AXON Upload/Download (Experimental)
- A.I. Vehicle Detect and Clean-Up (Experimental)
- Blood Spatter (Automatically move cast off plane to edge of the convergence point)
- UI Themes (Support custom colors like the good old days)
- Scale bar (Offer 'auto' mode to change with Unit settings)
- Vehicle Specs Database (New make/model/year Search feature)
- EDR (Steering input wheelbase entry)
Bug Fixes
- 3D poly-curve elevated offset issue
- Dim Tool HUD - Facing 3D should say Camera Facing
- Dimension Line - UI - Can't manually type into the Dim Length 3D Field
- Dimension Line - Set Arrow Size - Not auto-sizing arrows when off
- Grid emissive color issue
- EDR option should be available in "Legacy" license mode
- San Bernardino Sheriff vehicle models with logos - finished
- Model - Left Panel - Width and Length are reversed
- Object PBR material not showing in print
- Rectangle and Numbered Polygon objects color not matching print PBR base color
- CDT HUD - Normalize Pts form
- Auto detect objects that are far away from origin - try 100,000 ft away from origin
- Grouped Symbols, Explode Symbol - lose the Fill Color
- Trajectory Report not isolating each trajectory
- Label - UI - Swap Text color and fill color buttons
- DLC (downloadable content) update work
- Multi-Select - Lines - Not updating when you change thickness through the buttons
- Keyboard - Ctrl-C, Ctrl-V not working
- Signs - Fix referenced file paths
- Signs - Find Missing Files load issue
- Blood Spatter - Edit Droplets Form - Allow tabbing between controls
- EDR animation path snap issue
- EDR Steering input UI update
- EDR: Yaw Rate issue
- PC Crash import end KEP "crazy" spin
- Help manual link-include language code for German, French, Spanish-default English
- Help form doesn't translate any of the text
FARO Zone 3D 2023 Release Notes - November 2022
FARO Zone 3D 2023 Editions
FARO Zone 3D is available in the following editions:
FARO Zone 3D Pro (Replaces FARO Zone 3D)
FARO Zone 3D Pro features an array of drawing tools, and all the point cloud tools necessary to perform a field-to-finish workflow that allows you to seamlessly go from scans to a completed drawing. This edition includes:
- All features included in FARO Zone 2D
- Support for importing most types of point clouds
- A full lineup of point cloud tools
- Support for importing panoramic images along with point clouds (from FARO scanners)
- Virtual surveys
- Vehicle Specs Database and Slope Calculator
- Evidence placards
- Animation tools for creating fly-thru (or walk-thru) videos from your drawing
FARO Zone 3D Expert (Replaces FARO Zone 3D Advanced)
Includes all the features in FARO Zone 3D Pro, and high-end crash and crime reconstruction tools. This edition includes:
- FotoPoints, a photogrammetry tool that allows you to convert photos, from any source (cell phone, DSLR, drone, etc.) to point clouds
- Point cloud lighting and shading adjustments for realistic-looking point clouds
- Create Point Cloud models
- One-Step Registration tool that allows you to search SD cards and other media for .fls files (raw FARO laser scan files) from within the application
- HDR (High-Dynamic Range) Lighting provides ultra-realistic scene lighting
- PBR water and grass options allow you to include authentic ground effects in your drawings
- Crash and crime reconstruction tools, including skid analysis, crush, momentum, bloodstain pattern analysis (impact and cast-off), shooting trajectory, security, and import of Event Data Recorder (EDR) data
- Support for VR devices
FARO Zone 3D 2022 and Earlier Release Notes
