FARO Zone 3D
2026
2025
2022
Security Planning with FARO Zone 3D
FARO Zone 3D has several tools to help you visualize and plan security features with a 3D drawing.
Security Planning Tools
  1. To access the security planning tools, click the POWER TOOLS tab.
  2. Click the Security Tools icon.
  3. Select the security tool from the Security Tools menu.
  • FZ Security9.png Draw Camera Planner - Create a camera to place within a scene. A red grid illustrates the camera's field of coverage.
  • FZ Security10.png Draw Security Ring - Illustrate the threat level of areas surrounding a point with concentric rings.
  • FZ Security11.png Draw Security Halo - Generates a 360° grid illustrating the line of site from a position.
Camera Planner
This option places a camera in the scene with a grid illustrating the camera's field of view.
  1. Click the Draw Camera Planner icon in the Security Tools menu.
  2. Click to place the camera in the drawing.
  3. Use the properties menu to further customize the field of vision grid.
Properties Top Menu
  • Color boxes - Use the color boxes to change the alternating colors of the field of vision grid.
  • Layer - Place the camera on a different layer.
  • Preview Camera View - View the scene from the camera's point of view.
  • Next, Previous - Cycle through cameras in the scene.
Properties Menu
  • Name - Name the camera.
  • URL - Link the camera to a web address with the camera's live view, if available.
  • X,Y,Z - Change camera coordinates.
  • Rotation, Tilt - Change the camera's rotation or tilt.
  • View Angle - Change the camera's field of view.
  • Distance to Ceiling - Changes the top of the projected grid.
  • Distance to Floor - Changes the bottom of the projected grid.
  • Distance Max - Changes the distance of the projected grid.
  • Samples Horizontal, Vertical - Change the number of rays projected in the grid.
  • Show Sight Lines - Toggle guide lines showing the number of samples.
  • Update - Update the grid to reflect changes.
  • Open View - Preview the camera view.
Security Ring
Place a security ring in a drawing to illustrate levels of security around a central location.
  1. Click the Draw Security Ring icon in the Security Tools menu.
  2. Click to place the ring in the drawing.
  3. Move the yellow handles to resize a circle or the red dot to rotate the entire ring.
  4. Use the properties menu to further customize the ring.
Properties Top Menu
  • Layer - Place the ring on a different layer.
Properties Menu
  • X,Y,Z - Ring coordinates
  • Rotation - Rotate the ring to change the orientation of the text.
  • Aspect Ratio - Change the overall ring shape.
  • Zones - Customize the ring text, color, number of circles and more.
Zones
  • Color - Change the color of a circle.
  • Transparency - Change circle opacity.
  • Radius - Change the radius of a circle.
  • Dome - Replace the circle with a dome.
  • Description - Change the text within a circle.
  • Add Zone - Add another circle to the ring.
  • Remove Last - Remove the last circle.
Security Halo
Place a viewpoint with a 360° grid illustrating the line of sight from the position.
  1. Click the Draw Security Halo icon in the Security Tools menu.
  2. Click to place the viewpoint in the drawing.
Properties Top Menu
  • Layer - Place the viewpoint on a different layer.
Properties Menu
  • Name - Name the viewpoint.
  • X,Y,Z - Viewpoint coordinates
