Uninstall Instructions for FARO CAM2 Gage
Install Icon
Quick Steps
Here is all you have to do. Click the links to see details.
  1. Backup any files you want to keep.
  2. Uninstall using the Microsoft Windows Control Panel.
  3. Download and run the FARO® Clean Up Tool, version 1.0.4.3, released 16 March, 2017
Properly uninstalling software makes sure all FARO files are removed from your computer and keeps it running at peak efficiency.
Prepare
Time to Complete 30 minutes
Skills Needed
  • General computer skills
Prerequisites
  • Internet connection
  • Computer you use with your FARO software
Detailed Steps
  1. Back up any files you want to keep from the appropriate directories before you uninstall the software.
    • For CAM2 Gage
      ..\Users\userName\Documents\CAM2 Gage
  2. Uninstall the software using the Windows Control Panel. Select Start > Control Panel > Uninstall a program > Remove > CAM2 Gage.
  3. Click here to download and install the FARO Cleanup Tool.
  4. Run the Cleanup Tool by going to Start > Programs > FARO > FARO Cleanup Tool. The tool completely removes files, registry settings, and profiles that may remain after uninstalling the software.
    FARO Cleanup Tool
uninstallation, uninstaller, clean, reghost, regedit, re-image, reinstall, clean up tool, cleanup tool
