AnthroCAM
AnthroCAM Workflows
Legacy AnthroCAM® software provided control to legacy FaroArm® products. Listed below are sample workflows for common uses.
CAD to Part Inspection of a Dashboard Panel
This article demonstrates how to compare cut holes to a CAD file on a door panel.   Download the Method Sheet.
CAD to Part Inspection of a Door Panel
This document explains the process of inspecting the fiberglass dashboard panel for a semi while using a CAD file to check part accuracy.   Download the Method Sheet.
Creating an Import Macro for Reporting in Microsoft Excel
This guide demonstrates how to run a Learn/Execute program and generate a text report of measurement results.   Download the Method Sheet.
Inspecting a Tubing Fixture
This document explains how to inspect and align tubing section.   Download the Method Sheet.
Inspection of an Automotive Headliner
This article details how to inspect holes on an automotive headliner.   Download the Method Sheet.
Programming 5-Axis Laser Cutters
This guide explains how to create data for a laser cutter path using reverse engineering to create needed surface normals.   Download the Method Sheet.
Positioning Parts in Aircraft Engine Fixtures
This article demonstrates how to align to a fixture and inspect to verify parts of an aircraft engine fixture.    Download the Method Sheet.
Surface Inspection of a Polymer Car Door Panel
This document explains the process of measuring the surface warp of a car door panel and measuring/comparing the inner door surface to CAD data.   Download the Method Sheet.
Wingtip Lens Inspections
This guide describes the process of inspecting a Wingtip Lens using Surface Point Alignment.   Download the Method Sheet.
