Measure X
Common Measure X Workflows
Aligning Machine Rails
This document gives a brief description of how to level, square, and align two parallel rails with multiple segments comprising each rail.  Download the method sheet.
Calculating Radial Taper Length
This document provides a procedure for calculating the overall radial taper length for a cone or tapered cylinder.  Download the method sheet.
Calibrating TP-20 Touch Probe
This document gives a brief description of how to calibrate a TP-20 Touch Probe. Download the method sheet.
Comparing Measured Tube to CAD Tube
This document gives a brief description of how to compare a measured tube to a CAD model. Download the method sheet.
Converting a Learn File to a SCT File
This document describes the methodology of changing a *.xln file into a *.sct file.  Download the method sheet.
Customizing the Format of the Report and Header
This document describes the methodology of customizing the format of the report *.frm file and header *.dat file. Download the method sheet.
Determining Length Between Bore Centers
This document describes the methodology for determining the straight length dimension between radial bore centers.  Download the method sheet.
Rebuilding the SPC Graph Database
This document describes the methodology of removing old SPC data and rebuilding the SPC graph database.  Download the method sheet.
Updating Learn Files from 4.0 to X1.0
This document describes the process for updating Learn files from 4.0 to X1.0.  Download the method sheet.
Using a Laser Tracker to Level to Gravity
This document describes the process for using a Laser Tracker to adjust and level a machine part to gravity in real time. Download the method sheet.
Back to top
See Also
Keywords
measure, method sheet, measure x, xln, sct, spc, graph, chord, length, circle
