Measure 3/4
Measure Version 4 and Earlier Workflows
The articles below contain easy-to-follow tutorials for common legacy CAM2 Measure workflows.
Alignment Using Offset Points - Measure 4
This tutorial explains how to set up an alignment where the datum line for a part is two points with one point offset from the datum line by an known distance.   Download the Method Sheet.
Connecting the Tracker and Arm - Measure 3
This article details the procedure for connecting a Laser tracker and a FaroArm together in the same measurement session for CAM2 v.3.9.   Download the Method Sheet.
Using the Laser Tracker to Level to Gravity - Measure 4
 This document describes how to use a Laser Tracker to adjust and level a machine part to gravity in real time.   Download the Method Sheet.
Importing and Exporting in Solidworks and CAM2
This file explains Import/Export options for CAM2 and Solidworks software.   Download the Method Sheet.
CAM2 Measure Fundamental Concepts
This tutorial explains the fundamental measurement concepts required to use measurement devices and software.   Download the Method Sheet.
Lathe Verification and Alignment - Measure 4
This document describes two basic procedures for measuring a large-envelope lathe.   Download the Method Sheet.
