Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
Target Tooling Kits for the Laser Tracker
Target Tooling Kits contain accessories that enhance the capabilities of the SMR and the Laser Tracker. For an in-depth look at the components of the kit and their typical uses, see: Target Tooling Kit Contents and Usage for Laser Trackers.
Hard case kit layout shown, soft case kit contains the same items with a similar layout.
Target Tooling Kits are available in both metric and SAE versions, and in both hard case and soft case form. In addition to the kits, many items are available individually. Contact your FARO Sales Agent for ordering information.
Target Tooling Kit - Inches, Hard Case: Part# C-ACC-05455-001
Target Tooling Kit - Inches, Soft Case: Part# C-ACC-05455-002
Target Tooling Kit - Metric, Hard Case: Part# C-ACC-05456-001
Target Tooling Kit - Metric, Soft Case: Part# C-ACC-05456-002
Item Description Equivalent Replacement Part*
1 Pole Adapter, 1.5" SMR C-ACC-05425-000
2 1.5" Center Punch Adapter, Offset 1", 6mm punch hole
Replacement: 1.5" Center Punch Adapter, Offset 1.15", .25" punch hole
C-ACC-05290-001
3 Drift Nest, 1.5" (10x) C-ACC-05432-000
4 & 5 Pocket for 1.5" SMR (SMR not Included) N/A
6 1.5" Target Nest, Off 1", Shank 1/4", NEG C-ACC-05286-007
7 Offset Plate, 3"x2"x.25", .25" Dia C-ACC-05443-001
8 1.5" Target Nest, Off 1", Shank 1/8", NEG C-ACC-05286-005
9 Shankless Nest 1.5", Off 1", NEG C-ACC-05289-001
10 Hard Point, Off 1", hole 1/4" C-ACC-05424-001
11 .5" Tooling Ball, Off .5", shank 1/4" C-ACC-05446-000
12 Tooling Ball Adapter, Off 1" C-ACC-05445-001
13 & 14 Negative Drift Nest, 1.5" C-ACC-05433-000
15 Large End Adapter, Off 1", 1.5" C-ACC-05284-001
16 1.5" Nest-1" Off,.25" Shank, for Bar Ext C-ACC-05450-001
17 Magnetic Handle, 0.5" SMR C-ACC-05449-000
18 Transfer Punch C-ACC-05291-000
19 Bar Extension, 5" C-ACC-05441-001
20 Bar Extension, 10" N/A
Not Shown Hex L-key, English Kit N/A
2 1.5" Center Punch Adapter, Offset 25mm, 6mm punch hole
Replacement: 1.5" Center Punch Adapter, Offset 29mm, .25" punch hole
C-ACC-05290-002
6 1.5" Target Nest, Off 25mm, Shank 8mm, NEG C-ACC-05300-008
7 Offset Plate, 3"x2"x.25", 6mm Dia C-ACC-05443-002
8 1.5" Target Nest, Off 25mm, Shank 4mm, NEG C-ACC-05300-004
9 Shankless Nest, 1.5", Off 25mm, NEG C-ACC-05289-002
10 Hard Point, Off 25mm, hole 6mm C-ACC-05424-002
11 12mm Tooling Ball, Off 12mm, shank 6mm C-ACC-05447-000
12 Tooling Ball Adapter, Offset 25mm C-ACC-05445-002
15 Large End Adapter, Off 25mm, 1.5" C-ACC-05284-002
16 1.5" Nest- 25mmOff, 6mmShank, for Bar Ext C-ACC-05450-002
19 Bar Extension, 125mm N/A
20 Bar Extension, 250mm C-ACC-05442-002
Not Shown Hex L-key, Metric Kit N/A
* Equivalent replacement parts may vary in appearance, however they will be of equal function and specifications except where noted in the table above.
