Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
SMR Window Replacement Availability
Replacement windows can be ordered from FARO using part number 099-03913 (1.5" Windowed SMR) or C-ACC-03927-000 (7/8" Windowed SMR).  The collar of the SMR is threaded on and can be removed by hand. Once this collar is removed, the old window can be removed and the new window inserted and the collar can be threaded back on to the SMR. This can be done by the user, it does not need to be returned to FARO.
