CAM2 CAM2 - 2021
Quantum S Max
Quantum M Max
Quantum E Max
Gage Max
Gage
Fusion
Prime
Platinum
Legacy Quantum
Titanium
Advantage
Digital Template
3D Laser Scanner
Focus Core
Focus Premium
Focus3D X
Focus3D X HDR
Focus3D S
Photon
Laser Tracker
Vantage S
Vantage S6
Vantage E
Vantage E6
ION
Si
X
Xi
Legacy Gage
Bluetooth
Plus
Standard
Power
Serial FaroArm
Bronze
Gold
Silver
Design ScanArm
Design ScanArm 2.0
Design ScanArm 2.5C
Forensic ScanArm
Dimensions and Weight of FARO Tripods and Stands
In the following article you will find all the information on FARO® Tripods and Stands.
FARO offers a selection of mounting options and granite surface work carts. See the following articles for more information:
Current Products
Part Part Number Height Weight
Standard Carbon Fiber Tripod ACCSS8032
  • Fully folded for transport: 29'' (730mm)
  • 0 tubes extended (Minimum Height): 27'' (679mm)
  • 1 tube extended: 42'' (1079mm)
  • 2 tubes extended: 59'' (1489mm)
  • 3 tubes extended (Maximum Height): 76'' (1936mm)
5.7lbs (2.5kg) with Quick Release Mount
FaroArm and Tracker
Portable Folding Tripod w/wheeled soft carry bag 473-000008-000 24"-37.5" (0.61 - .95m) 29 lbs (13kg)
Rolling Stand* ACCS-STND-0013 (Formerly 15036 & IG-9) 44"-68.5" (1118mm - 1740mm) 185lbs (84kg)
Rolling Stand* ACCS-STND-0011 (Formerly 15037 & IG-10) 31"-43" (787mm - 1092mm) 158lbs (72kg)
Rolling Stand* ACCS-STND-0010 (Formerly 15038 & IG-18) 22.5"-27.5" (572mm - 699mm) n/a
Rolling Stand* ACCS-STND-0012 (Formerly 15039 & IG-24) 38"-56.5" (965mm - 1435mm) 177lbs (81kg)
*The Max Base Width for all models is 32.5" (825.5mm).
All dimensions are approximate.
Legacy
FaroArm and Tracker
Rolling Stand IG-9 43” to 67” (1092mm to 1701mm) n/a
Rolling Stand IG-10 28” to 42” (711mm - 1066mm) n/a
Rolling Stand IG-18 20” to 25” (508mm - 635mm) n/a
Rolling Stand IG-24 36” to 54” (914mm - 1371mm) n/a
FaroArm Portable Folding Tripod 15532 (This part replaces 14422)
  • Maximum Height - 41'' (1.0m)
  • Minimum Height - 31'' (0.7m)
  • Maximum Spread - 54'' (1.4m)
n/a
Laser Tracker Portable Folding Stand 15531
  • Maximum Height -50'' (1.3m)
  • Minimum Height - 29'' (0.7m)
n/a
Portable Folding Tripod ACCS0134 13''X14''X46'' (330mmX355mmX1168mm)
  • 32 lbs (15kg)
  • Shipping weight 70 lbs (32kg)
Portable Folding Tripod 11356 13''X14''X46'' (330mmX355mmX1168mm)
  • 32 lbs (15kg)
