2026
2025
Reset Settings to the Default Configuration for CAM2 Interface
If you are not seeing panels, windows, ribbons, or icons in the CAM2® user interface that you used to see, if a window is not working correctly, or if after you upgrade from one version of CAM2 to another you are not seeing parts of the user interface that you used to see; you can restore or reset the settings for the CAM2 interface to the default configuration or factory settings. There are two methods to do this.
Method 1:
Hold the Shift key on the left-hand side of the keyboard and then launch the software. Hold Shift down the entire time the software is launching. It can be released after you see the measurement window. If this doesn't work, restart the computer and try the procedure again.
Method 2:
Delete the preferences file. Make sure you have show hidden files and folder enabled from your folder options and navigate to:
  • Windows 7/10
C:\Users\(Your User Name)\AppData\Roaming\FARO Technologies\CAM2\xx\
where xx is the version number
Delete the preference file (Preferences.txt), and restart the program. If the panels continually change location on their own, it is recommended that you uninstall and re-install the software.
reset to default, panels, modification, viewing, revert,CAM2, windows, preferences, missing feature panel, readings, Shft, Ctrl, layout, default, ribbons, measurement window is not working
