Reporting Dimensions in Different Coordinate Systems in CAM2
In this article, you an find information on how to report dimensions in different coordinate systems in one report, using the grouping function provided in CAM2®.
Procedure
To report dimensions in different coordinate systems in one report, you can use the grouping function provided in CAM2®. At the top of the Features Panel, you should see a small folder icon. When the icon is selected, a new group folder will appear.
Features can be dragged and dropped into these folders. You can then right click on a folder and choose what coordinate system to associate the features inside the folder to.
When the group is added to the report, they will report from the desired coordinate system. Effectively, you can create a folder for each coordinate system in your file.
coordinate systems, dimensions, folders, groups, CAM2
