2026
2025
Tube Measurement - By Breakpoints Method in CAM2
The purpose of this article is to advise how to measure tubing / pipe using Measure Tube – By Breakpoints method.
Download a PDF of this procedure:  MS004: Tube Measurement - By Breakpoints Method
Information: This method is mainly used where no tube is present, but can be created using measured points to set a bend position. Measuring a tube by breakpoints, combines the measured end planes and breakpoints (bend positions) to construct the tube to the entered diameter and bend radius.
Preparation
  • Establish the Start and Finish end faces.
  • Identify the bend positions needed.
Measurement
From the Measurement ribbon select Tube by Breakpoints (also via Home -  Measurement gallery).
  • The Tube properties window will be shown:
    1. Name and Comments can be entered
    2. Override Diameter
      • enter tube diameter.
    3. Starting Plane / Ending Plane
      • Choose an existing plane, or Define to measure a plane.
    4. Default Bend Radius – enter default bend radius.
  • Click Create to start measurement.
  • The Measurement window will show prompt to Measure Tube - Start plane.
    • Probe a minimum 3 points to set the start plane of the tube.
  • The measurement window will then prompt to Measure Tube
    • Probe the position of each Break Point, using the green button.
      Note: Do not compensate after each point.
  • Once the final break Point has been probe, press the red button.
  • The Measurement Window will prompt to Measure Tube - End plane.
    • Probe a minimum 3 points to set the end plane of the tube
  • Once the end plane has been probed, the tube will be created.
See Also
Help Sheet, MS004
