4.x
Enhancing Scan Data Quality Using the SCENE Noise Compression Feature
The FARO® Photon Laser Scanner allows you to improve the quality of your scan data by its sophisticated “Noise Compression” feature. This feature, which has been introduced with version 4.1 of FARO SCENE and FARO Record not only reduces the fuzziness of your point cloud - at the same time it reduces the file size with practically no loss of detail.
Refer to the download link below for more information on this topic.
Click here to download: Tips and Tricks - Enhance Scan Data Quality Using Noise Compression
Note: This document applies to early revisions of the Scene 4.x release. By SCENE4.8, this Noise Compression setting has been removed and and replaced with Scan Quality, which is set at the scanner.
  • Was this article helpful?
