Georeferencing to Survey Control in SCENE
The georeferencing workflow has been improved in SCENE 2023. The following FARO® Academy video is a complete guide of using reference points from the field and aligning them to coordinates in the point cloud. Note this method applies to SCENE 2023 and later versions only.
If you employ georeferencing in your FARO SCENE workflow, you'll want to give this video a view. In under 14 minutes, Brandon Daugherty takes you through the new (and improved) workflow click by click.
New Georeferencing Workflow in SCENE
