5.x
Loading More Scan Files Simultaneously in SCENE
FARO® Scene allows you to load scan files with many million points and always tries to make best use of the available memory space. The total amount of points which can be held in memory at the same time depends on the amount of RAM available on your computer. In general, this is limited by Windows XP which cannot maintain more than 3GB RAM. Due to this fact, in some cases you may want to load more scan files than possible with the default settings. See the link below for more information.
Click here to download: Tips and Tricks - Load More Scans at the Same Time
Keywords: scans, FARO Scene, loading scans, load
  • Was this article helpful?
