2022
7.x
6.x
Using SCENE with a 4K Display
Using SCENE with a 4K resolution monitor or HD tablets, such as a Surface Pro, may result in stability and/or performance issues. Adjusting your PC's high dots-per-inch (DPI) scaling setting should result in improvements.
Details
  1. Right-click the SCENE icon on your desktop.
  2. Click Properties.
  3. Click the Compatibility tab in the SCENE Properties window.
  4. Check the Override high DPI scaling behavior box.
  5. In the dropdown menu, select System.
  6. Click Apply.
