2022
7.x
Using the Oculus Rift with SCENE
Quick Steps
  1. Connect headset and sensors to PC.
  2. Use Oculus app to calibrate headset.
  3. Open project in SCENE and click VR View on the Explore ribbon.
You can view a scan project with the Oculus Rift headset directly from SCENE. Follow these instructions to connect your Oculus Rift headset. In order to view a project you will need to download and install the Oculus Rift app, Steam, and Steam VR. You will also need to create a project point cloud for the project.
Prepare
Time to Complete 30 minutes
Skills Needed
  • General knowledge of Microsoft Windows
  • General computer skills
Prerequisites
  • Internet connection
  • Oculus Rift headset, sensors, controllers
  • Oculus App installed
  • Steam and Steam VR installed
  • An available HDMI port
  • Three available USB 3.0 ports
  • A minimum 3x3 ft play area (for headset calibration)
Supported Hardware
Oculus Rift
Setting up the Oculus Rift Headset
  1. Download and install the Oculus Rift app.
  2. Plug the HDMI and USB 3.0 Oculus Rift headset cables into your computer.
    Note: You will need a USB 3.0 port near the HDMI port. A USB 3.0 port has a blue interior.
  3. Plug the Oculus sensor cables into USB 3.0 ports, and place the sensors 3 to 6 ft. apart with the reflective side pointing at the play area.
    Note: Make sure to remove the protective covering from the sensor lenses.
  4. Open the Oculus app.
  5. If the calibration process doesn't begin automatically, click Devices in the left menu, and in the Configure Rift drop-down menu, click Full Setup.
  6. Follow the on-screen instructions to calibrate your controllers, headset, and sensors.
    Note: If your Touch controllers are not added, turn on the controllers. Click Configure Rift and select Pair Touch.
  7. Download and install Steam and Steam VR.
Oculus Rift App
  1. Open the Oculus Rift app.
  2. Click Settings > General > Turn on Unknown Sources. This will allow the use of SCENE with the headset.
  3. Open SCENE.
