Legacy Software
CAM2 Gage
Support Data Generation for Legacy-CAM2 Gage
Customer Service may require specific information about the computer that you have Measure installed on and may ask you to collect a *.nfo. This may be in addition to sending Log Files.
Attached is a tool that will automatically extract this information and save the information into a file named "CAM2_Support_Data.zip" that is placed on your Windows desktop. Send this .zip file to FARO Support. Copy the file "FARO Measure Support Information Retrieval.bat" that is attached to any location on the computer that has Measure installed and double click on it to run it.
If you have problems using this tool, the information can still be obtained manually, instructions to find the log files are in the link below. The instructions to obtain the *.nfo file follow:
With all versions of Measure, the file can be created by going to Start > All Programs > Accessories > System Tools > System Information. Then go to File > Save and save the file on your desktop.
If you are using Measure Q, go to Help > Generate Support Data. Once created, a message will appear telling you where the nfo file is saved.
Either method can take approximately 3-4 minutes to generate. Send the file to FARO Support.
NOTE: In addition to sending this *.nfo file, the Measure Log Files should be sent. Instructions to find them can be found by clicking here.
Click here to download: Measure Support Info Retrieval
CAM2, generate support data, nfo, system information, 10
