Adding Images to the Quicktools Program in Measure 10
On the left side of the main Measure 10 measurement window there is a gray cube located at the bottom of the report option. This is the image creator option. Image creator allows you to associate pictures to you Quicktool macro program. All you need to do is click on it and it will prompt the image creator window. Import your images and add the desired points to take according to your Quicktools program.
QT, 10, macro, Measure 10, SCT, import, JPEG, bmp, png
  • Was this article helpful?
