2026
2025
Creating a GDT Perpendicularity Call-out in CAM2
How to apply a GDT perpendicularity call-out to a feature.
Download a PDF of this procedure: GDT006: Creating GDT Perpendicularity Call-out
Preparation
Creating the GDT Call-out
  • Select the GDT tab
  • Highlight the required feature in the Feature panel
  • From the ribbon select GDT006PerpendicularitySymbol.jpg Perpendicularity
The GDT panel will open in the lower LH corner of the UI
Note: If the GDT icon is ‘greyed-out’ this details that the selected feature does not support this call-out.
  • Within the GDT panel:
    1. Click into the tolerance, and enter the required value
    2. Select the required datum
The call-out will be calculated and the result will be shown in the GDT label displayed in the 3D viewer.
Note: To display results in the GDT label select via View > GDT Label > Level of Detail
Copying GDT Call-outs to Other features
This allows multiple features of the same type to have the same call-out applied
  • Apply the call-out to the first feature
  • Highlight the first feature
  • Right click and select Copy Tolerances
  • Multi-select other features
  • Right click and select Paste Tolerances
  • Message ‘Do you also want to paste the GDT tolerances?’, select Yes
The GDT call-out will be applied to the selected features, and the GDT label will be displayed.
How it’s Calculated
Perpendicularity measures the condition of a plane or axis, at a right angle (90 degrees) to a datum plane or axis.
A tolerance zone is applied, that is exactly 90° to the datum feature. The measured surface or axis of the feature, across its full length, must remain within this zone to be deemed as acceptable.
Note: When measuring the feature to be checked, the length of the feature is critical to this calculation. Therefore the full length of the feature must be measured.
This on a drawing...    Means this when calculated...
See Also
GD&T, Help Sheet, GDT006
