2026
2025
Tube Measurement - By Line Segment in CAM2
The purpose of this article is to advise how to measure tubing / pipe using Measure Tube – By Line Segment method.
Download a PDF of this procedure:  MS005: Tube Measurement - By Line Segment
Information: This method is used where no tube is present, but can be created using measured lines to set tube straight positions.Measuring a tube by line segments, combines the measured end planes and straight start / end positions to construct the tube to the entered diameter and bend radius.
Preparation
  • Establish the Start and Finish end faces.
  • Identify the straight section positions needed.
Measurement
From the Measurement ribbon select Tube by Line segments (also via Home -  Measurement gallery).
  • The Tube properties window will be shown:
    1. Name and Comments can be entered
    2. Override Diameter
      • enter tube diameter.
    3. Starting Plane / Ending Plane
      • Choose an existing plane, or Define to measure a plane.
    4. Default Bend Radius – enter default bend radius.
  • Click Create to start measurement.
  • The Measurement window will show prompt to Measure Tube - Start plane.
    • Probe a minimum 3 points to set the start plane of the tube.
  • The measurement window will then prompt to Measure Tube
    • Probe the of the start and end of each straight section, using the green button.
      Note: Do not compensate after each straight.
  • Once the final break Point has been probed, press the red button.
  • The Measurement Window will prompt to Measure Tube - End plane.
    • Probe a minimum 3 points to set the end plane of the tube
  • Once the end plane has been probed, the tube will be created.
See Also
Help Sheet, MS005
